« 1 ... 62 63 64 (65) 66 67 68 ... 91 »
Re: Datsun 1200 ute restoration and sale
From melbourne
thanks mate ,it sounds like to me that your paint may be stuft,how many cracks are there???if there are heaps of tiny ones that look like a spider web sort of pattern,thats called crows feet or crazy cracks its basicly the result of the paint work breaking down ,you can sray over it but it will never come up that good,your best to sand it right back and reprime it again,then go from there so your got a good base to work on,
no point spending lots on paint when its just going to turn out bad because of the stuff your painting over ,heres something to keep in mind
spraypainting is 80 percent preping and the rest is just the finish,do a good job on your prepwork and you will certainly me a lot happer with the end result,cheers
Posted on: 2007/3/27 3:53
From melbourne
well managed to complete my release set up tonight so pretty happy as it all works as i hoped it would heres a few shots
so here i drilled a hole in the top area of the latch and mounted a s/s thin cable.......
Posted on: 2007/3/27 4:11
From melbourne
heres the cable going down into the rear of the 1/4 panel .............
and these are the locks im using ,there exactly what i was after and work well....
ok can you guess what that is attached to the end of the lock?????????
no????? well actually its a special picture hanging clamp,but i turned it into something use for to attach the cable to the lock and still being able to adjust the cable lenght and remove it all together if i want,groovy little gadget,you just press down and thread the wire in and then it clamps it there,they say it can hold up to 75kgs of weight but the latches pressure would be no where near that amount so i think wear pretty safe!!!!
heres the hole for the lock theres one on either side of the lower inner 1/4s,was a bit tricky getting the drill in there do make the hole but managed to do it after much stuffing around
so we got the latch with the cable attached at the top then it runs down the tube into the 1/4 and attaches up to the back of the lock ,these next pics are very hard to make out but there taken thru the hole in the tail light panel ,you can sort of see the back of the lock with the cable attached to the picture hanging hook thing
and heres the lock from underneath
so there you go ,your battery goes flat you cant get into the tray casue the cover is closed by electric central locking,what do you do???????????hahahah well pull out the magic keys stick one in each slot and turn ,kablamo shes unlocked and you got the access again ,thanks you thank you your too kind hahahahhahaha ya mother
Posted on: 2007/3/27 4:27
From Far, far away
Are you planning on hiding the cables? Also, what are you using to make it an electronic release?
Posted on: 2007/3/27 4:37
From melbourne
well if you go back and read thru what ive posted up youl se that im building full side covers that will cover every thing also you will see that ive allready installed the electric central locking for the latches
cheers
Posted on: 2007/3/27 4:47
Possibly you could also fit something like these under the bonnet to make it easier and quicker to jump start or attach a charger to the battery.
Posted on: 2007/3/27 5:02
From Adelaide, Australia
MLS where can you get them? Thats just what i need so I run my timing light!
Posted on: 2007/3/27 5:07
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
VPW in Melb2ourne have them
VPW Remote Battrey Terminals
or somewhere like Rocca Bros (if they still exist) or Sprint Auto Parts in Adelaide would probably have them.
Posted on: 2007/3/27 5:13
Cheers mate!
Sorry for the thread hi-jack evilbetty!
Posted on: 2007/3/27 5:22
IPRA Build
From UK
Some form of dust cover over those locks would prob be useful.
Top build..... Keep up the good work!!
Posted on: 2007/3/27 10:03
Capitalization is the difference between "I had to help my uncle Jack off a horse.." and "I had to help my uncle jack off a horse.."
