« 1 (2)
Re: K40 Toyota gearbox>>>>A15 motor
From South Africa
Ok so it wasn't that bad.... actually it being right over the starter, made it to be much easier....
Posted on: 2007/3/17 10:27
From Perth WA
God damn i wish i could TIG weld and have the resoources to do this kind of stuff!!!
Great work!
What are you doing clutch/flywheel wise?
Posted on: 2007/3/17 10:49
Chris...
From South Africa
Std A15 Flywheel with a copper clutch and a Std pressure plate....
a picture of the stripped gear in the K40...
Posted on: 2007/3/17 11:59
From Cape Town ZA
It looks exactly the same as the one I've got behind my 4AGZE, which is the 21R... I don't know, maybe I inadvertently picked up one of those good boxen as well...???
Posted on: 2007/3/20 18:37
1200 GX Sedan
New(being installed)
4AGE 20V NA
Old
4AGZE 16V turbo
196.5KW/283NM
800m - 200km/h
400m - 12.3s
A farmer makes a plan
From sydney
In Australia we here a lot about "Aussie ingenuity" and in New Zealand they talk about "Kiwi ingenuity", do you South Africans have a similiar phrase? because you seem to have plenty of ingenuity.
Posted on: 2007/3/20 22:07
From Cape Town ZA
Mmmmm, here in ZA we normally say, "'n Boer maak 'n plan". It directly translates into "a Farmer makes a plan", but it rather serves as a saying, referring to the ingenuity of people.
3Rotor, if you take a quick look at the box I have, in the pictures I attached to my earlier post, do you think that mine is also of the W58 stable? It does look exactly the same as yours, and study the photos as much as I like, I can't find a difference...
Posted on: 2007/3/24 16:24
1200 GX Sedan
4AGE 20V NA
Old
4AGZE 16V turbo
196.5KW/283NM
800m - 200km/h
400m - 12.3s
From South Africa
nope that is most definately not a "21R" box or otherwisely known to be a T50......You got yourself a very nice box. The T50 is by all means too an awesome box to have, but I've seen people rate the W57/8/9 boxen to be able to hande 300HP easily, and if the car it's in, is not heavy, probably a little bit more...
These are some Toyota gearboxes. From left to right they are - T50, W50, W58, R158. Shamelessly copied from here
ours is the one 2nd from the right....
same as the W57 only the 5th gear differs...
and the w59 with a very short 1st gear
a link with some nice pictures of the T50
Posted on: 2007/3/24 23:03
From Cape Town ZA
Ah, I see, says the blind man to the deaf person over the broken telephone...
Well, then I'm happy as a pig in sh!t. And I presume an all up weight of 715kgs would probably classify as "not heavy" then...
What did you pay for your box? I got mine for R2000, and the place I got it from has a mountain of them lying around... and they are selling them as 21R/T50 boxen...
Posted on: 2007/3/26 2:57
1200 GX Sedan
4AGE 20V NA
Old
4AGZE 16V turbo
196.5KW/283NM
800m - 200km/h
400m - 12.3s
From South Africa
got mine for 2500.
Posted on: 2007/3/30 20:42
« 1 (2)
