how can i tell if a h190 has an alloy centre from the outside?
From bathurst nsw
i just picked up a 620 ute (1500) with the h190 in it (for the diff for a later ca18 conversion) and the housing is coated in surface rust but the centre is a different colour to the housing like a silver/alloy colour type compared to the rusted half painted black iron type colour of the housing.
if i new how to post pictures up i would i think the trouble is that they are too big
any help would be good.
thanks kurt
Posted on: 2007/3/30 22:21
My car gets me from A to B...Just faster ;)
Re: how can i tell if a h190 has an alloy centre from the outside?
From Mudgee NSW Australia
Yeah Woody the 620 ute diffs have the alloy carrier 4.625:1 if it looks silver a it would be alloy a steam clean and some heavy duty alloy cleaner will bring it up nicley.When your closer to doign the CA18 install give me a call Im often over your way can give some pointers.
Cheers Andrew
Should look like this minus the disc brake setup Open in new window
Posted on: 2007/3/30 22:55
If In doubt run more BOOST
From South East QLD
The Alloy centres have a Welch plug above the pinion bearing in the alloy casting
Posted on: 2007/3/31 1:37
From bathurst nsw
thanks guys and yes it does have a welch plug on top of it so thanks for the hint.
i might try to clean it up or even sell it because i already have another one sitting on the shed floor
thanks guys.
Posted on: 2007/3/31 12:13
From California
hmm, why not test it with a magnet?
Posted on: 2007/3/31 13:25
