« 1 ... 66 67 68 (69) 70 71 72 ... 91 »
Re: Datsun 1200 ute restoration and sale
From melbourne
and into the booth for a bit of a spray....
first a bit of 2pak primer to seal the wood then some matt black or black with matting base as the case was.........
so thats about it for the moment will carry on with that if i get time tomorrow
Posted on: 2007/3/31 3:55
Quite a regular
From Tasmania
Laughed my arse of over that last pic of the tray about the gravel in it :)
Should you use two lights in there to give a more even light? I'm thinking you want it to be nice and bright anyway ;) Cold cathodes would probably give a more even light aswell. Unless those LEDs are diffused a bit. Either way stay away from those Neons in my opinion. cold cathodes are the same kinda thing except better :) Better light, smaller and not as fragile.
Posted on: 2007/3/31 23:37
From melbourne
hhahaha yeah you like that eh haha,yeah i actually got a neon for this set up but i found that it was a bit jumpy wasnt really that stable or that bright so the led tube that i ended up with is alot better option,this should be finished by the end of the week im hoping but im very busy at the moment so maybe not,
heres a small update......
Posted on: 2007/3/31 23:52
From melbourne
so this is a metal lamp cover i made up its spose to cover the light and direct the light up into the sign......
Posted on: 2007/3/31 23:57
From melbourne
so heres the sign all dumbed up looks pretty good i must say ,all the little pieces coming together well
Posted on: 2007/4/1 0:03
From melbourne
next i had to add a few little l brackets for a piece of perspecs to sit on,
then cutting the perspecs sheet to make a window
a bit more choping and a test fit
then another test fit with all the bits
Posted on: 2007/4/1 0:10
From Adelaide, SA the drift state
man you come up with some cool ass sh1t. cant wait for this thing to be done.
Posted on: 2007/4/1 1:58
From SE Melbourne
Mad Mike would be more than proud! Keep up the awesome work!
Posted on: 2007/4/1 2:01
Mildman, Datsunless
From melbourne
thanks guys very much apreciated,should have a small update later tonight...........
Posted on: 2007/4/1 20:29
From melbourne
ok well i finished the sign,screwed the perspecs cover down and all done,also i left the plastic on the front just to protect it a bit will i stuff around..............
Posted on: 2007/4/1 22:02
