Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#61
Re: A-Series Manifold Templates for Autocad - Come n get 'em
kue1000
Posted on: 2007/4/3 18:51
ok sign me up!!
I'm also keen for that group shipping to perth - will see if the transport company i use for work picks up in SA on the way from melb - might make a big diff from AusPost prices - only prob is people would have to pick up from me!? Rally1200 I:2 E:2 Dattoman_1000 I:2 E: 2 dattodevil I: 1 pager I: 1 E: 1 Beattie I: 2 (1 steel braced, oval & 1 alloy braced, oval) Cable_tie I: 3 alloy 2 Mild E: 5 (all Oval) LAGWAGON: I: 1 E: 1 boofhead: I: 1 E: 1 Grunterhunter I: 2 E: 1 Tnpshow I: 1(MS) E: 1 ang94541 I: 1alloy oval, 1steel oval E:3 rally1200 style Ianey I: 1 alloy 1 steel E: 1 Sidedraught 2x mild steel exhaust kue1000 I:1Alloy E:1 steel - oval
#63
phunkdoktaspok
Posted on: 2007/4/3 22:05
Since i feel like being nice. A word of advice. The one piece exhaust flange (as pictured below) will aide in future manifold fit up. Just check out joys of a old holden straight 6 if you feel the need to seperate the flange.
But my main reason for this post. - the arrows drawn below. Make note of the shape under the exhaust port for cylinder 4. Failure to add this shape to the flange will make the manifold unable to fit smallblock A series unless its to be cut.
#64
TnPshow
Posted on: 2007/4/3 22:57
Yep and that's precisely the reason for my concern about clearing the block - that area imparticular.
I have an A10, old school A12, A14 and an A15 block to test against, not to mention CNC milling and laser cutting abilities at work to test my designs against (laser cutting stops at acrylic and thin fibreglass - no metal unfortunately). Hopefully I will get to cut a one piece test tomorrow on a piece of acrylic. PS - If anyone wants to test one on their head, let me know - I'll mail you one! (not too many though )
#65
rally1200
Posted on: 2007/4/5 12:16
Sorry mine is all fitted up at the moment, but that back section was only tight for me when i had 3.5mm shaved off the head and then it only took a small amount of grinding to fix. but i had no problems with the inlet manifold. The bottom brace helps in keeping the exhaust outlet aligned.
#66
ang94541
Posted on: 2007/4/5 14:32
The thickness where you have arrows is about 12mm /
#67
boofhead
Posted on: 2007/5/1 4:48
Rally1200 I:2 E:2
Dattoman_1000 I:2 E: 2 dattodevil I: 1 pager I: 1 E: 1 Beattie I: 2 (1 steel braced, oval & 1 alloy braced, oval) Cable_tie I: 3 alloy 2 Mild E: 5 (all Oval) LAGWAGON: I: 1 E: 1 boofhead: I: 1alloy 1steel E: 2 (oval ports) Grunterhunter I: 2 E: 1 Tnpshow I: 1(MS) E: 1 ang94541 I: 1alloy oval, 1steel oval E:3 rally1200 style Ianey I: 1 alloy 1 steel E: 1 Sidedraught 2x mild steel exhaust kue1000 I:1Alloy E:1 steel - oval just changed mine and a bump as well
#68
Wombat_racing
Posted on: 2007/5/7 13:02
Is this still going to happen or has every one already got there bits.
I dont want to add my name to the list if its all been done already.
#69
TnPshow
Posted on: 2007/5/7 13:12
No it's still happening i'm just waiting on a sample to verify the latest exhaust design.
After I get that back it's all go!
#70
1200rallycar
Posted on: 2007/5/7 15:32
Rally1200 I:2 E:2
Dattoman_1000 I:2 E: 2 dattodevil I: 1 pager I: 1 E: 1 Beattie I: 2 (1 steel braced, oval & 1 alloy braced, oval) Cable_tie I: 3 alloy 2 Mild E: 5 (all Oval) LAGWAGON: I: 1 E: 1 boofhead: I: 1alloy 1steel E: 2 (oval ports) Grunterhunter I: 2 E: 1 Tnpshow I: 1(MS) E: 1 ang94541 I: 1alloy oval, 1steel oval E:3 rally1200 style Ianey I: 1 alloy 1 steel E: 1 Sidedraught 2x mild steel exhaust kue1000 I:1Alloy E:1 steel - oval 1200Rallycar I: 1 alloy 1 steel (oval ports) E: 2 steel You can view topic.
