Re: GAUGES
From brisbane
defi guages are good if you dont want a speedo, the link bellow has a pic of the gauges in my dash
the guages are 2,1\6"
fuel level,fuel pressure,air\fuel,oil pressure,oil temp,trans temp,diff temp,boost\vac,volts,water temp (at radiator),head temp, and the three on the way are pyrometer and two brake pressure (going to have a willwwod brake bias valve between the two brake pressures)
160mph speedo and 10k tacho are 3.3\8"
my dash
Posted on: 2007/4/11 15:04
Re: GAUGES
From Schofields
don't think i'll b needing that many!!!!!!!!
Posted on: 2007/4/11 15:18
Re: GAUGES
From Adelaide, SA the drift state
dont get monaro or GTIR get like one of those old school ford ones. the lil balck ones. they are small and tuff lookin
Posted on: 2007/4/11 15:46
Re: GAUGES
From Schofields
it'll end up being the same colour as the car..
Posted on: 2007/4/11 16:07
Re: GAUGES
Not too shy to talk
From londonderry/penrith
or you can go to dakota digital gauges they will put what ever you want how ever you want and works out cheaper then autometer anyway www.dakotadigital.com i know its an old post but just letting you know what i fit to customers cars i build
Posted on: 2007/7/2 9:54
« 1 (2)
