#1 wanted...... h145 centre with 4.11:1 ratio
1200rallycar Posted on: 2007/4/10 17:50
as it says,
pls pm
#2 Re: wanted...... h145 centre with 4.11:1 ratio
1200rallycar Posted on: 2007/4/12 8:28
how hard are these to find, would rather not chuck in a 165, dont need the strength or weight
#3 Re: wanted...... h145 centre with 4.11:1 ratio
cheater_5 Posted on: 2007/4/12 12:59
ancient myth says that they come with alloy carriers in wagons..... i have a wagon but have yet to check it
#4 Re: wanted...... h145 centre with 4.11:1 ratio
Dodgeman Posted on: 2007/4/12 14:59
The Datsun 1000 sedans & coupes used the H145 in 4.11 to 1 ratio. Utes & Vans used a lower ratio of 4.375 to 1, but were still H145's & these all used the alloy carrier.
The alloy 4.11 to 1 diffs sometimes found in Aussie 1200 wagons are B10 diffs while the genuine 'factory option' 4.11 to 1 diffs that were available for 1200 wagons in Japan used an iron carrier according to my parts. book.
As far as I can tell, the alloy 4.11 to 1 diffs in 1200 wagons were fitted here in Australia. [but I have no proof yet]
The construction of the alloy & iron diffs differed in that the alloy one used a fixed length sleeve + shims to set the pinion bearing preload. This was costly to produce, so they went for the cheaper "compressible sleeve" in the iron diffs. Both are good, but the earlier design is easier to service & the fixed sleeve can't compress further under high loads.
The later design is quicker & cheaper to make, but involves a complete tear down just to replace the front seal & a new compressible sleeve is required also in order to do the job.
Cheater_5
Remember, your car isn't a wagon in the traditional sense, but a Van, & as a work vehicle, it stands more chance of having the lower ratio as standard.
#5 Re: wanted...... h145 centre with 4.11:1 ratio
Tyrie Posted on: 2007/4/12 15:07
I'm intrigued, why does wagon now have two 'g's?
#6 Re: wanted...... h145 centre with 4.11:1 ratio
Dodgeman Posted on: 2007/4/12 15:18
spellcheck program. I just went with the flow.
OK, OK, it was bugging me, so I have removed the offending surplus G's
#7 Re: wanted...... h145 centre with 4.11:1 ratio
1200rallycar Posted on: 2007/4/12 15:49
damn i had a 1000 diff at one stage, pretty sure i gave it away though (you didnt take it did you dodgeman?)
so anyway got a spare 1000 sedan or coupe centre???
#8 Re: wanted...... h145 centre with 4.11:1 ratio
Dodgeman Posted on: 2007/4/12 16:09
No, it wasn't me. Once I switch the H150 LSD into my coupe, the original will be available, but don't hold your breath just yet.
It should be a good one too as the car has only 41,018 original miles on it.
Is this for Claire's coupe?
#9 Re: wanted...... h145 centre with 4.11:1 ratio
1200rallycar Posted on: 2007/4/18 9:00
yeah for claires coupe... still looking
#10 Re: wanted...... h145 centre with 4.11:1 ratio
dattoman_1000 Posted on: 2007/4/18 15:31
3 went to the crushers with the 1000 sedan I wrecked recently
Shame about that
I'll have a look
But I think I used all mine up on the racecar
Tends to spread them abit with the torque
