garrett turbo question SOME ! MUST NO THE ANSWER
I have a turbo that has on the housing.
a/r 60 m24
I am confident its a t28.
but my friend has a s15 and he used to have a s14 and he said it is a
ball bearing turbo off a s15
but i thought it was a bush type off a s14
can some 1 confirm.
Posted on: 2007/4/12 15:50
Re: garrett turbo question SOME ! MUST NO THE ANSWER
From Sydney
Is it that hard to tell that it does or doesnt have ball bearings?? Wouldnt it spin easy as with em, with no play at all in comp wheels??
Posted on: 2007/4/12 15:55
lol...
i have got a few turbos
and been threw alot.
the only way i have heard is
oil feed has a reducer inside the thread.
5 bolts on the exhaust.
can some confirm if true..
or any1 familiar with the numbers and i no they are sizes but the s15 and s14 are different
all i need to no is what mine is off.
As s14=bush s15=ball
Posted on: 2007/4/12 15:59
Any 1 got any idea
Posted on: 2007/4/12 18:53
Hey Demo,
Your correct.
I just double checked my old turbo which was a s14 bush bearning t28.
Glad i could help.
Posted on: 2007/4/12 19:22
I grabbed this from NS.com a while ago.
It doesn't explain exactly but might help
Jap PS13 14411-50F00
AU/NZ S14 (pre-facelift) 14411-75F00
AU/NZ S14 (facelift) 14411-75F00
Jap S14 (pre-facelift) 14411-69F00
Jap S14 (facelift) 14411-82F01
Jap S14 (Autech/270R) 14411-RP801 (Same as S15 early MT turbo)
Jap/ NZ S15 (early*) 14411-91F00 Manual model only
Jap/ NZ S15 (early*) 14411-69F00 Automatic models
Jap/ NZ/ AU S15 late* 14411-75F00 Same as NZ S14 and same for both Auto and
Posted on: 2007/4/12 19:30
where can i get them numbers or match with my turbo...
Posted on: 2007/4/12 19:39
Are the numbers the same your s14 turbo
IM still not 100% sure
any1 no how to identify
Posted on: 2007/4/12 19:48
From brisbane
Why don't you email Garrett Australia?
Posted on: 2007/4/12 19:55
1985 CA18DET Datsun 1200 ute
1969 A12 Datsun 1000 coupe
From Mudgee NSW Australia
Demo the number you have found is on a lot of diff turbos. I have seen it on a stock ca18 T25 and T28 of silvia the number you need to find exact type should be on a little alloy tag on the centre peice or core of the turbo. Give me this number and I shoudl be able to shed some light on the info your after.
Cheers Andrew
Posted on: 2007/4/13 5:21
If In doubt run more BOOST
