#1 1200 ute dying??
dobby3103 Posted on: 2007/4/14 4:43
Hoping someone can help me, my 81 1200 ute sometimes when accelerating won't accelerate, like engine is choking?? have changed points, coil, rotor arm, air cleaner and have had carbie rebuilt. Any help much appreciated.
#2 Re: 1200 ute dying??
rb20 Posted on: 2007/4/14 4:52
maby its your fuel pump
#3 Re: 1200 ute dying??
dobby3103 Posted on: 2007/4/14 4:58
i thought it might be the pump, but it seems to be pumping
#4 Re: 1200 ute dying??
rb20 Posted on: 2007/4/14 5:13
try spark plugs dizzy cap or leads and doble check you have points gap right
#5 Re: 1200 ute dying??
dobby3103 Posted on: 2007/4/14 5:28
points gap has been triple checked. Leads, plugs and cap are all near new
#6 Re: 1200 ute dying??
Dodgeman Posted on: 2007/4/14 5:31
Did you change the fuel filter?
#7 Re: 1200 ute dying??
dobby3103 Posted on: 2007/4/14 5:32
yes, that was one of the first things i changed when this problem came up
#8 Re: 1200 ute dying??
dobby3103 Posted on: 2007/4/14 11:14
anyone had this problem before???
#9 Re: 1200 ute dying??
Datsfullysik Posted on: 2007/4/14 12:14
i had a similar problem with a mazda ute, i took off the petrol tak nd cleaned all the lines and the tank itself, i had about half a kilo of #### stuck in various places in the lines, and under acceleratino fuel would be choked by the muck stuck in the lines. Maybe it's time to clean out your tank?
#10 Re: 1200 ute dying??
dobby3103 Posted on: 2007/4/14 13:09
sounds like a possability. was your problem intermittent aswell?
