RE: SU's again
Not too shy to talk
From La Mesa
I run the datsun GX motor with the 38MM SU carbs. The needle/seat for the float has two kits for the roadster 16010-14625 washer/gaskets and 16010-14628 hardware. The fuel needle in the
roadster is a M-39 or M-43which maybe to rich. The GX carb uses a M-76 or M-83 needle. The difference is the diameter. Measuring from shoudler to the tip of needle the following
distances 0.100, 0.400,0.0700,1.00,1.400. The first two are .090& .091,.088&.0875,.082&.081,.076&.075,.071&.0695,.062&.0665. The next two .088&.088,.087&.0875, .081&.0815,.074&
.0755,.069&.070,.0635&.0625. Also the needle/seat for the 38mm GX carbs will so fit, but I do not have that number here with me. I set the carbs up using s tire thick depth gage. Set
both the nozzles to 4MM as a starting point and use a small hose to hear the difference in both carbs as it is running. If you have any more question just ask.
Posted on: 2000/10/12 10:12
RE: SU's again
From Castro Valley,CA USA
Thanks, I found that i have the M43 needles. Do you know where I can find the M76 or M83 needles?
Also I think the stock 1200 carb needle/seat valves might work. They fit and i can adjust the height. We'll see. I'm going to try to find
the parts you listed.
thanks
Angelo
Posted on: 2000/10/20 9:13
RE: SU's again
Thanks for the info. Apparently Gross needle/seat valves are available for roadster SU's from Classic
Datsun Motorsports (classicdatsun.com).
They also have various fuel needles.
Are you able, or willing, to send me a copy of that list of needles? it would be greatly appreciatated.
Thanks
Angelo
ang94541@aol.com
Posted on: 2000/11/2 12:32
