radiator
wondering if any one can help me wot radiator do i use for a ca18det in a 1200??
Posted on: 2007/4/27 4:52
Re: radiator
From SE Melbourne
S13 is OK, N13 or N14 pulsar is also OK. I've heard VN commodore ones work too...
Posted on: 2007/4/27 4:55
Mildman, Datsunless
Re: radiator
From Canberra
where are the outlets on these rads? are they both on the drivers side?
Posted on: 2007/4/27 4:58
Re: radiator
From Perth WA
VN has them on the same side as a A series rad. They should actualy fit in a 1200. they are a close fit in a 1000 but just too wide. cheap too, about $150(trade) brand new!
Posted on: 2007/4/27 5:03
Chris...
Re: radiator
From SE Melbourne
S13 has both outlets on the drivers side.
I think N13 has the lower outlet on the passenger side...
Posted on: 2007/4/27 5:11
Mildman, Datsunless
Re: radiator
From Canberra
so s13 fits in well? got dimensions? I might get one for my 4agze
Posted on: 2007/4/27 5:19
Re: radiator
From SE Melbourne
About 600 wide and around 350 tall? Bit cold to go out and measure it tonight....I have the dimensions somewhere - but a good fit for height - pretty thin too.
I think the Nissan Exa rad is the same too - I checked some of them out at Burson/Repco - went through their parts book, but as I got an S13 rad with the engine I didn't end up having to buy one.
Posted on: 2007/4/27 7:13
Mildman, Datsunless
Re: radiator
cheers guys will c wot i can find
Posted on: 2007/4/28 0:06
Re: radiator
From Blue Mountains,Syd,Aus
VL radiator as well i think
Mat
Posted on: 2007/4/28 2:32
Re: radiator
From Tannum Sands Qld
Only the S13 Ca18 will fit the CA conversion the SR has the top hose on the passenger side.
Im using the R32 skyine radiator, twice as thick in the core but its about 20mm higher so you need to mod the bonnet frame, but you get better cooling.
Posted on: 2007/5/9 14:03
