suspension set up for a 1200 coupe
From Sydney
I am starting to put thoughts together for the suspension set-up for my 1200 coupe build... I have a reverse leaf set up for the rear but need to start to consider what poeple are having success with for the front end.
The car is not a daily driven car at all.. it will only have race rally set up and the focus of this build is to build a serious tarmac rally car.
Love to hear your thoughts
Posted on: 2007/4/29 23:27
Cheers,
Marty
Re: suspension set up for a 1200 coupe
From sydney
This what you are looking for.
Competition suspension manual.
Posted on: 2007/4/30 1:02
From California
i for one have never seen nor heard of anybody doing up their suspension according to that manual
Posted on: 2007/4/30 1:35
From sydney
Someone must be doing it properly, they cant all be turning their springs upsidedown and heating their coils with oxy.
Posted on: 2007/4/30 2:01
From San Jose, California
Someone must be doing it properly, they cant all be turning their springs upside down
How well does that work, handling wise? I imagine there would be alot of friction between the leaves, causing an unstable spring rate.
As for the man's question, I am going to use some VW rabbit bilsteins strut inserts revalved for the front (I'm 99 percent certain they fit- they've got a 1.5 inch diameter), some bilsteins revalved for the rear (will Chevy Camaro ones fit?) and some 175-250 lb/inch springs on coil-overs for the front. Re-bush everything with polyurethane. I won't use a rear sway bar, but I'm hoping to upgrade the leaf springs somehow to make them work better.
Front camber plates are also in order.
Posted on: 2007/4/30 10:40
-Daniel
From Las Vegas USA
Over the years I ended up inadvertantly doing exactly what is in the suspension set up book.
I'm running the Nissan Comp rear springs , 7/8 front bar 1/2 rear , traction bars , 4.11 LSD , Z car brakes (280ZX) etc. and the car handles very very well.
For Tarmac Rally I'm not sure I would do this. The ride is someting like 105-110 mm and if you drop wheels off the inside of the road (as is common) you're going to be beating the heck out of the undercarraige.
I would think your minimum ride hieght will be 140 mm range. As for coil overs they are not a must have , the 240Z springs fit on the 1200 struts and with some revalved inserts that would be a cheap way to go , along with modded rear springs (stiffer and re-arched) with some uprated shocks.
The biggest thing is do your home work , the suspension is cheap relative to getting a cage, seats belts , fire system , fuel cell and all the other safety gear.
Tom
Posted on: 2007/4/30 16:12
Which years 240z do you get the springs from Tom? Are these the front 240z springs or the rears? Is the rate streetable? I may use those.
Posted on: 2007/4/30 16:36
-Daniel
I found this on another forum about he 240z spring rates:
i have a 71 240z and recently measured the front and the rear spring ratesw... stock measured is front about 85 to 90 lbs/in and the rears came out to be about 90 to 100 lbs/in.......
Seems kinda soft to me. Maybe sport springs for the 240 would work well?
Posted on: 2007/4/30 17:31
-Daniel
From Brisbane, Australia
worked alright for me...
my front end was just as "rough". Cut down Holden Gemini coils (aka Opel Kadett?) on stanza struts with Monroe shocks & 120Y sway bar.
I'll be doing the same to my 120Y coupe. Cheap and very effective. Not that I'd recommend that for a tarmac rally where you're shocks are going to get a workout on long stages and you want a bit more travel than I had, but its fine for sprints and hillclimbs.
Posted on: 2007/4/30 18:31
L18_B110 - I've been looking through your old posts- tell us about the rest of the suspension setup on this car- what did you do for camber up front?
Posted on: 2007/4/30 22:54
-Daniel
