« 1 (2)
#11 Re: Moving ute leaf springs inwards
Wattage Posted on: 2004/6/15 6:45
Well, you already know the answer to that question....especially by looking at your attached pic and considering the rear ends are pretty much identical between the wagons and utes!
So, I guess now I have to try and plan out the process of moving the chassis rails inwards. I wouldn't imagine I would have to move them in too much to get a 7" wide rim under there.
Also, at the same time, I want to make sure that the modified rails are going to be as good as, if not better (stronger) than they were as stock.
Leigh
#12 Re: Moving ute leaf springs inwards
phunkdoktaspok Posted on: 2004/6/15 13:16
I will just point it out again to make sure its 100% clear to you. To be registered as modified production vehicle you are not allowed to narrow the width of the chasis along its entire length.
" So now you cant say you didnt know"
This is why I said if you keep it looking original no one will ask any questions.
You are allowed to mini tub the car but you cant move the rails.
Remember 1200 utes are everywhere and they are a popular vehicle and chances are who ever does your blueslip has seen one before, my car on the other hand arent all that abundant. Having said that, I still know of a few 1200 utes which have passed blueslip with this done without question.
Just making sure you realise.
Cheers Steve.
#13 Re: Moving ute leaf springs inwards
Wattage Posted on: 2007/4/29 22:16
Diggin up an old post here guys...
Well, I'm at the point where I just need to fit up my shortened diff to finish off all the major work to the drive train. Below are a couple of pics of the standard ute leaf spring mounts. Basically, I need to move the mounts to the inside of the chassis rails (+10mm) and remount them.
For the rear, I was thinking about welding a piece of RHS just inboard of the chassis rail and then make a new mount and attach it. I think this will be the easy one.
As for the front, I'm really not sure what to do here as I want the area to be nice and strong, yet still retain a semi-stock look. The only thing I can think of here is to use some RHS that welds to the back of the cab like the stock spring rail, and merge the two together.
I would appreciate any input from people that may have a better idea for moving the mounts inwards whilst still retaining the strength. I've been through plenty of options and I'm at the point where I need someone else to look at it as it's starting to lose all meaning!!
Cheers...
#14 Re: Moving ute leaf springs inwards
PIGDOG Posted on: 2007/4/29 22:50
this is something im thinking of trying on my spare sedan, just drilling out the vast number of spot welds holding the rail on then just moving it in a bit to see what is possible
should be fairly easy to do to a ute as its a flat floor
and im with phunk.....no one will ever be able to pick it as long as you jeep it looking stock
#15 Re: Moving ute leaf springs inwards
phunkdoktaspok Posted on: 2007/4/30 5:38
Im sure you can figure it out with this pic. just make the mounts accept leaf springs. Do the same at the back with straight crossmember and mounts to accept leaf shackles. In the pic, swap out the bars for the leaf springs.
« 1 (2)
