a15 turbo motor for sale
From campbelltown (sydney) australia
hey guys again i want to advertise my a15 a basic run down the whole engine was rebuilt top tp bottom, with brand new oil pump and water pump bottom up: fully balanced front pulley to clutch plate. a14 block a15 internals,low comp std pistons with chrome top ring,steel headgasket same as speedway racecar, arp headstud kit ported gx head oversized stainless steel valves inlet and exhaust, double valve springs, turbo grind cam profile. also the block has been modified by having radiator hose shortened with an adapter to use modern day radiator hoses the bigger ones the radiator elbow also has a ca18 det water temp sensor mounted in a machined boss. all work except for the custom machine work was all done by Jeff Taylor the motor hasnt run yet but its all been cvered in clevite bearing lubricant so isnt rusty at all.
secondly hanging off the side its a t25 off a ca18det no shaft play other than normal clearances, custom exhaust manifold with external wastegate street gate 38 turbosmart with 2.5 inch dump pipe.
on the other side is a half built injection manifold has all injectors mounted with custom billet fuel rail ca18det throttle body, ca18det oxygen sensor sard fuel pressure regulatorits been made using weber maifold and a fair bit of machine work.
i couldnt put a price on it but i wanna get rid of it and will sell it to the bidder that comes up with a price im happy with so if someone wants to bid 1000 bucks then you wont even get a reply to ur pm except to call u an idiot for wasting my time. thanks guys i hope to hear from someoen soon, this engine cost me over 6 grand to build and i will sell it for half that i would just really like to see it running one day as i think its performane will eclipse my ca18det if finished properly .
Posted on: 2007/5/1 3:35
* caution, sunglasses must be worn to view my ca18det *
Re: a15 turbo motor for sale
come on ppl someone must want this even if they just want the motor i will not separate unless someone just wants the engine and not the turbo as someone has their eye on it
Posted on: 2007/5/3 2:54
From Mudgee NSW Australia
pm sent
Posted on: 2007/5/3 3:28
If In doubt run more BOOST
bump im again looking for someone to buy my turbo a15 specs are below theres no need for me to list them again, im willing to takde offers of around 2500 bucks just wanna get rid of it as i no longer need it.
Posted on: 2007/7/22 9:30
From perf
why you selling mate? it will make good power but that turbo is under sized.
edit... what were you plannin on doing with the ignition?
Posted on: 2007/7/22 9:40
undersized? i dunno bout u but if a turbo can make over 200kw on a ca18det it can do enouh for a 1.5....reason im selling is i have a ca18det ute now, about the ignition call jeff taylor tell him whos engine it is and he will get the buyer and electronic setup. if anyone is suspicious about the parts thathave gone into it jeff taylor will still have all the receipts of the buildup as do i. parts total almost 6000
Posted on: 2007/7/22 9:45
From Coondle, WA Australia
Pm sent dude
Very intrested.....
Posted on: 2007/7/22 10:15
EARTH FIRST! - We can mine the other planets later...'
'69 Blue 4 door Project Daisy (http://www.datsun1000.com/TopicView.asp?TopicID=668)
(https://pcmhacking.net/forums/viewtopic.php?f=15&t=5640)
(http://mx5cartalk.com/forum/viewtopic.php...
From perf
yes that turbo would work well but be limited to about 170hp at the treads.... maybe... as the exhaust wheel is ceramic and limited to 14psi. for all the work you have put into biulding the motor that would be a dissappointing result... considering with a better turbo and around 20psi it should be good for around 240hp. all guestimates of course! but i think they would be in the ballpark. i dont think you will have trouble selling it. my old man spent $1400 on the pistons alone for his turbo set-up. so if your reading this and half interested jump on it. you couldnt even biuld the motor yourself for this much.
Posted on: 2007/7/22 10:53
Im with you Picko... Very keen even though the exhast stuff probally wont fit Daisy, and even the intake side might be questionable. The motor is probally worth that much alone!
Kegs still keen.....
Posted on: 2007/7/22 10:55
Why does everyone seem to think CA18 t25's have a ceramic exhaust wheel? It's not the case.
Posted on: 2007/7/22 14:43
