« 1 2 (3)
Re: clutch??
From Perth
I am using 4AGE clutch on mine with a celica 5 speed
Oh by the way did I mention my flywheels ready to pick up........whoooooooppppppppeeeeee
It weighs in at just under 4kg apparently. Can't wait to get it here from Melbourne
Posted on: 2003/3/4 13:35
Re: clutch??
You lucky man! One day Ill get it from alloy tech or whatever he call his business
Posted on: 2003/3/6 13:34
Re: clutch??
The talk on the [url=
http://www002.upp.so-net.ne.jp/sunnytruck/q-dt.htm]Sunny Truck[/url] web site is to use the March (Micra) Turbo clutch:
Normal 30210-H5004 clutch: bonding power 280kg
NISMO 30210-RS100 bonding power 550kg
Using the NISMO pressure plate cover, there is the following harmful effect:
1. Due to the heavy pedal effort, the clutch cable wire eats into the casing of the clutch wire. (Replacement every year is recommended)
2. The clutch release lever eventually breaks, and the clutch becomes unable to be engaged.
March Turbo clutch part numbers:
Disk: CO10M-18085
Cover: 30210-H3122
Posted on: 2003/3/10 7:15
« 1 2 (3)
