« 1 (2)
Re: diff for ca18det datto ute who running wat
If you plan on getting it engineered I wouldn't rush into putting the mini spool centre in because an engineer won't pass a locked diff.
Posted on: 2007/5/7 16:24
From Bris-Vegas
I'm running a R31 LSD & went through exactly the same thought process about 1 yr ago....
Decided the extra cost of the cut down R31 was more than compensated by the increased driveability.
Posted on: 2007/5/7 16:32
CA18DET '74 1200 ute project
From Geelong, Vic
if you can do it your self you could get away with only spending around $200 on a not rebuilt open centre 28 spliner....worked for me
Posted on: 2007/5/7 16:43
From perth airport
yea in perth the r31 lsd diff is hard too find
Posted on: 2007/5/7 17:07
From Mandurah, Western Australia
If you get a diff cut down and your ute is not engineer approved yet the whole diff assembley needs to be approved.
To combat this I used a diff out of a Corolla 30-55 series, They are available in 3.8 , 4.1 , 4.3 ratios so it gives you a chance to experiment with what ratio is best and they only cost about $50.00 - $100.00 and replacement axles $20.00
When my coupe is engineered and on the road I will have a borg warner out of a vp commodore cut down. If you want this done a place called classic restoration in perth can do this. Not cheap though.
Posted on: 2007/5/7 21:02
From Newcastle
I got a vr commodore houseing with pintara 411gears all cut down 31 spline axels and full spool shes guna rip nuts lol rated 2 850-900hp over kill but its not guna brake lol
Posted on: 2007/5/7 21:24
« 1 (2)
