what sway bar?
From Adelaide. SA
Hey there, just wanting to see what sway bars people are using (if any) on the rear of their 1200 sedans?
Any opinions would be appreciated
Cheers. Adam
Posted on: 2007/5/7 19:28
It's not for the money and its not for the applause!
"Live life, follow your dreams",
Peter Brock
Re: what sway bar?
From Schofields
i was under the impression that a 120Y sway bar could be used or is that just for the ute?
Posted on: 2007/5/7 20:06
Re: what sway bar?
From Adelaide. SA
I dont know, just trying to find out what I can use or what is better for my 2 door sedan. I took it out to Mallala race way on Sunday and the rear was a bit "skatey"
Adam.
EDIT: that was my 500th post
Posted on: 2007/5/7 20:10
Peter Brock
Re: what sway bar?
From southern sydney "the shire"
120y's dont have rear sway bars. people do put 120 FRONT bars in 1200's though if thats what u mean?
Posted on: 2007/5/7 20:11
Re: what sway bar?
From Schofields
could be i dunno luke was saying we need to get a120Y sway bar so he could possibly mean the front
Posted on: 2007/5/7 20:16
Re: what sway bar?
From Tamworth , NSW
he has stated at least twice that he wants info on 'rear' swaybar options
Posted on: 2007/5/7 20:21
Re: what sway bar?
From Melbourne AUS
excuse my ignorance but if the rear was "skatey", wouldnt fitting a rear sway bar add to that problem as the rear would be more rigid?
or was the skateyness a result of the bodyroll?
Posted on: 2007/5/7 21:00
1973 B110 A12
Re: what sway bar?
From Adelaide, Australia
What sort of rear springs do you have adam, also what shocks?
Posted on: 2007/5/7 21:06
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
Re: what sway bar?
From Sydney
In my opinion, 1200's need to be soft in the rear on the circuit. A good set of springs and no sway bar an you are good to go.
Also stiffen up the front. 20mm bar of a 120y is the goods.
However if you require a rear bar, I used to use an aftermarket "Selby" rear swaybar designated for a 120y wagon rear. 16mm from memory.
Posted on: 2007/5/7 21:39
Re: what sway bar?
From Melbourne Aus.
I was thinking about using a Gemini rear sway bar, whiteline even have a kit for a larger unit,
eg
whiteline
Posted on: 2007/5/7 21:42
