« 1 ... 5 6 7 (8)
Re: Building the A-series???
From Vancouver WA. U.S.A.
Any one have any suggestions?
Posted on: 2007/3/26 20:00
BE sure to check out my coupe build thread and feel free to leave comments good or bad.
[url=http://datsun1200.com/modules/newbb/viewtopic.php?topic_id=36107&fo
From Perth Western Australia
Hey grease monkey,
I'm doing about the same as you in terms of building up a streetable but hot A series - I'm using the A14 as a base with standard heads - going the twin 36 webber option.
I'm also trying to work out a cam compression, valve springs and all the specs for the build, which is how i stumbled apon this thread.
So onto your question,
Yella Terra here in aus +(613) 9555 5522
(www.yellaterra.com.au) make roller rockers for the a-series in a variety of ratios I'm told - hope this help ya source some.
Good luck with the build
Posted on: 2007/5/9 15:08
« 1 ... 5 6 7 (8)
