« 1 ... 6 7 8 (9) 10 11 12 ... 21 »
#81 Re: A-Series Manifold Templates for Autocad - Come n get 'em
Dundee1000 Posted on: 2007/5/9 1:37
hukkay shaggit, I'm in, and up for the pickup at Neils BBQ dat party...
Rally1200 I:2 E:2
Dattoman_1000 I:2 E: 2
dattodevil I: 1
pager I: 1 E: 1
Beattie I: 2 (1 steel braced, oval & 1 alloy braced, oval)
Cable_tie I: 3 alloy 2 Mild E: 5 (all Oval)
LAGWAGON: I: 1 E: 1
boofhead: I: 1alloy 1steel E: 2 (oval ports)
Grunterhunter I: 2 E: 1
Tnpshow I: 1(MS) E: 1
ang94541 I: 1alloy oval, 1steel oval E:3 rally1200 style
Ianey I: 1 alloy 1 steel E: 1
Sidedraught 2x mild steel exhaust
kue1000 I:1Alloy E:1 steel - oval
1200Rallycar I: 1 alloy 1 steel (oval ports) E: 2 steel
Wombat Racing 1 ovalport inlet, 2 exhaust
Teretonga I: 2 alloy (oval ports) E: 2 steel
Dundee1000 1 alloy oval, 1 Steel exhaust.
#82 Re: A-Series Manifold Templates for Autocad - Come n get 'em
1200GXman Posted on: 2007/5/9 3:53
OK guys.
Need some advice. I can get mine made for free. Altough to make it complete I will still need the template of the flange for the webers to bolt to.
I just have some questions with regard to the intake manifold:
1. I measured my spare SU intake manifold's thickness of the part that bolts to the cylinder head. It is 15mm thick. The aluminium I can get is only 8mm thick. Will it still be up to the job?
2. I do not know what grade the aluminium is that they are going to use. MUST it be 5083 or can 6061 also be used for this job.Will contact the guy tomorrow to find out what aluminium he will use.
Thanks.
#83 Re: A-Series Manifold Templates for Autocad - Come n get 'em
TnPshow Posted on: 2007/5/9 10:26
8mm should be fine performance wise. The reason we went with 10 is because the exhaust was too and this makes the 2 surfaces even when bolted up.
I have dimensions for a DCOE. I will do this tonight when I get home.
I will also Update all the files as DXFs.
Stay tuned!
#84 Re: A-Series Manifold Templates for Autocad - Come n get 'em
TnPshow Posted on: 2007/5/9 22:54
Bump...
Ok DCOE pattern is done - get it HERE
On second thoughts I'll leave the dxfs of the other flanges until I can verify the designs on the weekend...
#85 Re: A-Series Manifold Templates for Autocad - Come n get 'em
1200GXman Posted on: 2007/5/10 17:46
You are our Datsun hero!!!!!
#86 Re: A-Series Manifold Templates for Autocad - Come n get 'em
picko Posted on: 2007/5/10 19:59
ok they could come in handy 1 day! have added my name at the bottom. how do we go about paying and how much?
Rally1200 I:2 E:2
dattodevil I: 1
pager I: 1 E: 1
LAGWAGON: I: 1 E: 1
picko: 2 exhaust, 2 intake
cheers
#87 Re: A-Series Manifold Templates for Autocad - Come n get 'em
A14force Posted on: 2007/5/10 20:38
What about doin the oval intake ports for a GX head? The GX heads have bigger ports than the A14/A15 ovals do.
#88 Re: A-Series Manifold Templates for Autocad - Come n get 'em
dattoman_1000 Posted on: 2007/5/10 21:55
Die grinder
This is getting fun isn't it
#89 Re: A-Series Manifold Templates for Autocad - Come n get 'em
1200GXman Posted on: 2007/5/10 22:25
I PM'ed TnPshow about the same question because my GX cylinder head is still standard non-ported. He replied that the oval templates are drawn for a stock GX cylinder head. PM him just to make sure.
#90 Re: A-Series Manifold Templates for Autocad - Come n get 'em
boofhead Posted on: 2007/5/10 22:42
will the weber flanges be available as part of the group buy laser cutting ???
