Re: 1200/180B brake/strut question
From Geelong, Vic
180b control arms can fit somehow...havnt looked into it
but once the lower control arms are fitted, then the 180b struts will obviously go onto them
you will just need to change the spring perch on the strut to a smaller one to fit in the 1200 strut tower, also need to use the 1200 strut tops
you will also need the 180b tierods and outer tierod ends and i think you use the 180b radious rods
you can make it work, just i havnt done it so cant tell you exactly what to do
but 180b brakes wont fit onto 1200 struts
Posted on: 2007/5/12 11:49
Subject Poster Date
     1200/180B brake/strut question 1200wag 2007/5/12 11:43
       Re: 1200/180B brake/strut question PIGDOG 2007/5/12 11:49
         Re: 1200/180B brake/strut question 1200wag 2007/5/12 14:14
           Re: 1200/180B brake/strut question PIGDOG 2007/5/12 14:18
             Re: 1200/180B brake/strut question 1200wag 2007/5/12 14:34
       Re: 1200/180B brake/strut question matbighat 2007/5/12 15:10
         Re: 1200/180B brake/strut question PIGDOG 2007/5/12 17:19
