wat botl size are the door hinges??
From Adelaide
hey guys
i have to drive an hr away to get door hinges and i need to no wat size the bolts are..
the door side are a 12 socket...
but wats the car side..
cheers
Posted on: 2007/5/13 11:31
Re: wat botl size are the door hinges??
From Brisbane Australia
8mm ftom memory same as most engine bolts, go to a bolt shop
Posted on: 2007/5/13 16:21
From Adelaide
wtf..
i said im going to get hinges but i dnt wanan take a toolbox if i no wat size socket they are to take them off
Posted on: 2007/5/13 19:26
From Adelaide, Australia
The bolt is a M8 (8mm) size bolt.
A 12mm socket will do the job. Someone may have replaced them at some time and you may need a 13mm socket.
Posted on: 2007/5/13 19:36
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
