Oil filter magnet - Opinions
From Adelaide, Australia
Ebay link
I dont think I would buy one, but sticking some magnets with tape to the oil filter doesnt seem a bad idea.
Posted on: 2007/5/13 19:04
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
Re: Oil filter magnet - Opinions
Well anything that helps remove abrasive particles from the oil has got to be a good thing, particularly when an engine is new or newly rebuilt as the rings & bore produce a lot of micro particles during the break in/ run in period.
Many use the sump plug magnet to draw out iron particles in suspension. These things are a pain to clean, but the amount of metal that they collect is amazing & that alone makes them worthwhile.
Baaaa
Posted on: 2007/5/13 19:13
Love your Datsun.
Treat it well.
like alot of automatic transmission oil pans, camry ones i believe have two magnets in the bottom to catch any metal filings from wear etc... and your right there a bastard to get it off
Posted on: 2007/5/13 19:16
I think it would be better to attract metal to the filter not the sump plug, at least its trapped in the filter not sitting below the crank.
Posted on: 2007/5/13 19:21
IPRA Build
From Sydney, Australia
Yes, a hose clamp and a couple of high powered hard drive magnets attached to the outside of the oil filter will do the job..
Posted on: 2007/5/13 19:24
From South Africa, Bloemfontein
Hmmmm, somewhere I have a old speaker magnet lying around. Might aswell put it to good use then.
Posted on: 2007/5/13 19:27
1977 Datsun 1200GX
From Perth
I use hard drive magnets too
Strong lil bastards
I have 5 or 6 attached to various parts of the sump pan
Posted on: 2007/5/13 19:44
The advantage of the sump plug magnet is that it can be removed & cleaned at oil change time & oil pan magnets, even the outside ones, work day & night, running or not.
The oil filter one traps the metal in the filter & is disposed of with the filter, but I wonder just how good it is at removing material from oil that is rushing by at fairly high speed.
Ahhh who cares, even a little is better than none. So now we can use magnets to not only heal our bodies, but to prevent injury to our engines.
Mmmmm magnetism, natures mirracle.
Baaaa
Posted on: 2007/5/13 19:55
Love your Datsun.
Treat it well.
yeah..any is better than none.
Posted on: 2007/5/13 20:04
From Perth WA
I say bollocks! Metal particals that can pass thru a oil filter dont do any harm. Otherwise oil filters would be finer.
All this product does is steal your money and clog your oil filter so the oil pump cant pump oil and your motor seizes. Quality product
Chris...
(1) 2 3 »
