rollcage
datsun 1200 coupe rollcage
seamless pipe steel
8 point cams approved
newcastle/hunter area pick up only
$500.00
bump
Posted on: 2007/5/13 19:41
Re: rollcage
From Melbourne, Australia
how did you get it out of the car
and more importantely...
how would someone go about getting this in their car?
i pressume its all one piece...
might be keen if i dont have to chop my roof off to get it in,
Posted on: 2007/5/13 19:43
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: rollcage
From Mudgee NSW Australia
1200Rallycar it would be a bolt in type.They come ready made in both weld in and bolt in a lot more work fitting a weld in cage.
The main hoop goes in first You need to have the interior seats ect striped out. Then its a matter of bolting and clamping all the other bits on making sure to keep them as close as possible the the pillars and roof line.
Posted on: 2007/5/13 19:46
If In doubt run more BOOST
Re: rollcage
are bolt in cages still cams approvable for circuit racing or similar?
i pressumed being cams approved it was a welded cage, as this is required for rally now
Posted on: 2007/5/13 19:48
1200 Coupe Rallycar
Re: rollcage
When I had my cage made at Bond rollcages in sydney Craig (converted) also had one made his was bolt in mine weld in both passed cams log book no dramas unless they have changed the rules in the last year or two!! The alloy cages arent allowed anymore unless its already logged with cams (changed around 6 years ago)
Posted on: 2007/5/13 20:12
Re: rollcage
From Adelaide, SA
Bolt ins are still alright. Check the manual for approved designs though.
Is the steel Cold Drawn?
Posted on: 2007/5/13 20:15
Re: rollcage
Not too shy to talk
Hi Castrol.....You have a PM!
Cheers
PH
Posted on: 2007/7/16 0:40
Re: rollcage
From melbourne
bolt in is still ok if the log book comes with the cage.
does the log book come with cage?
Posted on: 2007/7/16 6:58
Re: rollcage
From Murrumburrah N.S.W.
Is the roll cage still available?
Posted on: 2007/10/1 10:16
