A14 into 1200 sedan
From Gold Coast, Qld
hey guys can anyone tell me wat it takes to fit an A14 motor and gearbox into my 71 sedan.. iv heard that its a straight swope so yeah.. any help would be greatly appreciated
Posted on: 2007/5/12 19:42
'71 1200 Sedan... Deconstructing
Re: A14 into 1200 sedan
From Penrith, Sydney, NSW
<------<-------<------- tech section and search function in that direction. Everything you need to know and a f##k load more!!!!
Trav
Posted on: 2007/5/12 19:58
"If the doors of perception were cleansed, every thing would appear to man as it is......infinite"
From The Shire, Sydney
there are 2 types of A series motors, known as early and late. the difference being the engine mounts.
the engine mounts on the later motors sit 40mm further back than the early ones so measure that up before you start.
if theyre different then you will have to get a crossmember from a later model 1200.
and i think they changed the engine mounts around 73-74
Posted on: 2007/5/12 20:30
Project: Bagged, RB25 260c
Daily: 3.8L V6 720
From sydney australia
What you need is either new engine brackets, made up to a pattern 1200Rallycar posted on here a fair few years ago (go to the photoalbum, click on 1200rallycars album,then browse through til you see it), or you could find the engine crossmember from a 1200 ute with the 120y style engine, & the A14/15 will drop right onto it, with 120y engine brackets.
Again there are comparison photos on this site showing you the differences. If you're really desparate, you could try ordering one from a Nissan dealer to see if they're still available. That'd be the expensive way, but.
With the gearbox, there isn't any other way than making a U shaped piece that goes between the mounting holes & the gearbox. I posted a couple of photos of such a beast once, so just click on 'more photos from B310GX' & scan through.
Also, don't fail to look in the technical section, it takes photos like the ones 1200rally & i posted & puts them into articles so the new people can benefit from this. The days when you could wander through a wrecking yard & find something that might work are past, with most cars being frontwheel drive & the older cars disappearing from the lines.
Posted on: 2007/5/14 10:41
From gold coast QLD australia
PM Sent
Posted on: 2007/5/14 11:23
GO RACING,GO HARD OR GO HOME!!
SLY OLD FOX..................
From Adelaide, SA
MadDat do brand new ute crossmembers.
(HERE)
Posted on: 2007/5/14 11:59
