« 1 2 (3)
Re: strut brace for 1200 where 2 find
From Adelaide
Im making up 15 sets, to suit 1200, 120y, 1600. Price im not sure yet, still waiting on a price for machining of the ally rod. They are having left and right threded rose joints, so that they can be set without un-bolting.
Posted on: 2007/5/14 20:34
i looked at doing them for 1600's when i did mine but you need to make up 2 different end plates as the strut top bolt orientation is rotated 180deg between the 1200/120ys and the 1600
edit : also if you can spin the bar when it's in place are you looking at using a straight bar between the towers ?? cos there'll be clearance problems over the CA's SR's and Aseries with big air filter assemblies ...
Posted on: 2007/5/14 20:38
From In front, and pulling away.Sometimes around Sydney....ish!
Put my name down for one.
Posted on: 2007/5/14 20:42
Lifes good when your on BOOST!
From Adelaide
boofhead, yes the end plates are different, i'm not getting the holes laser cut, i'll drill them using a jig i made after.
The upstands i'm making are up a bit higher so a straight bar clears the ca in my car, i have to test it to see if it will clear other motors. If not i have access to a bender, so should be able to make them work with most combos.
Posted on: 2007/5/15 6:03
From California
sssute, you're making alloy tri-bars?
Posted on: 2007/5/15 11:20
From Adelaide
Yes, i was going to make one for my car, as i wasn't shore wether any one would want to go to the extent for themselves. If there is intrest i will make more of them.
Posted on: 2007/5/15 11:25
From Canberra
I'll get a tri-bar, but I'm not sure in strut tower-firewall distance is the same for 1200s and 120Ys?
Posted on: 2007/5/15 13:07
« 1 2 (3)
