« 1 (2)
Re: Decomp plate
From adelaide
from my experience with 9:1 and an intercooled injected setup, detonation was still a problem on 10psi. This was an l20b mind you but general principals are all the same, the a14 may have a better head design too but id run the plate, if it werent broke dont fix it! I now run approx 8.3:1 and have no pinging problems anymore, i also removed all sharp edges (hot spots) from the combustion chambers, i just rounded them slightly.
Posted on: 2007/5/16 13:48
1200 restoration project moving slower than it actually is
Re: Decomp plate
From Brisbane
Yeah.... where do you get this gasket stuff? Hylomar?... Sikdatto did you run a decomp plate and run 2 head gaskets or just one?
Posted on: 2007/5/16 17:59
OLD SkOOL POWeR!!! [color=CC0000]"with the sound & smell of twin 40s at full throttle!!!" [/
Re: Decomp plate
Hylomar is an ACL product an you can find it at the shops that sell ACL gaskets etc etc.
Posted on: 2007/5/16 18:03
Re: Decomp plate
From Gold Coast
My old 1600 ran an injected L20B turbo.. had a fairly thick spacer ( not exactly sure how thick ) and it ran 8.2:1.. ran 13psi all day without a prob.. i actually ran 12psi without a cooler for a while... but the air intake temps were reaching around 95degrees C!!!
I just ran a head gasket either side and never really had a prob
Posted on: 2007/5/16 18:31
« 1 (2)
