Re: RX7 S4 Calipers
do they still use 4 stud or 5?
because if it was 5 stud that would be greta with a hilux diff.
Posted on: 2007/5/16 17:02
Re: RX7 S4 Calipers
From Geelong, Vic
still 4 stud, uses the original hubs
what stud pattern size are you after, ford or holden?
Posted on: 2007/5/16 17:08
Re: RX7 S4 Calipers
From Adelaide
I have designed a conversion using the S4 Rx7 calliper working with a VW Golf rotor mounted to a 200B strut.
It was what I needed at the time.
No reason it can't be modded to suit other struts, the same basic suck it and see process will apply.
A CAD drawing is available for anyone who wants to have a look.
No Engineers certificate is supplied
No liability is accepted
I had to go to 15" alloys with this conversion.
Probably not a big issue with a 1600 [factory wheels are 13"] but may be too much for a car which started with 12" wheels.
I think there are legal issues going more than +2" in wheel diameter
Perhaps the tyre placard could turn up missing
Posted on: 2007/5/16 17:37
Nissanman - just trying to help...
Re: RX7 S4 Calipers
From Melbourne, Victoria
no worries :)
buying them through maddat comes with an engineer report which is a bonus
Posted on: 2007/5/16 18:05
Re: RX7 S4 Calipers
I need ford 5 stud on the front so it will match my hilux diff.
does anyone know how to do that.
Posted on: 2007/5/16 18:25
Re: RX7 S4 Calipers
From Brisbane
oan878- Mick (1200U) is getting custom hubs turned up on the lathe to suit commodore 5stud pattern.
My plan is to do the same. They will be a replicate of the 120Y hub used with the S13 Brake setup.
Posted on: 2007/5/17 3:01
Re: RX7 S4 Calipers
Quite a regular
From Melbourne, Australia
If your interested in 5 stud, this is what I've got. Mine are commodore stud pattern, but this kit is available in ford stud pattern also. Touch on the pricey side though!! It's a kit from hoppers stoppers in melbourne.
[img align=right]http://datsun1200.com/modules/myalbum/photo.php?lid=8936&full=1[/img]
Posted on: 2007/5/17 3:17
When all you have is a hammer, everything looks like a nail.
Re: RX7 S4 Calipers
From Burbank, CA
that starts to get messy using Rx7, Golf and 200b parts. Will it work... I suppose... I'd rather keep the parts all in 1 family, but if it works and it's what you got, then good job, that's probably harder than slapping S13 parts on he 120Y
Posted on: 2007/5/17 3:19
|||\ 81 KPB310 /|||
Re: RX7 S4 Calipers
From Adelaide
thanks for all the replies and help, keep em comin :)
Posted on: 2007/5/17 3:54
Re: RX7 S4 Calipers
From Burbank, CA
all that heavy stuff adds unsprung weight too...
Posted on: 2007/5/17 7:53
|||\ 81 KPB310 /|||
« 1 (2) 3 4 5 6 »
