Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#11
Re: RX7 S4 Calipers
oan878
Posted on: 2007/5/16 17:02
do they still use 4 stud or 5?
because if it was 5 stud that would be greta with a hilux diff.
#12
Re: RX7 S4 Calipers
PIGDOG
Posted on: 2007/5/16 17:08
still 4 stud, uses the original hubs
what stud pattern size are you after, ford or holden?
#13
Re: RX7 S4 Calipers
Graemes50
Posted on: 2007/5/16 17:37
I have designed a conversion using the S4 Rx7 calliper working with a VW Golf rotor mounted to a 200B strut.
It was what I needed at the time. No reason it can't be modded to suit other struts, the same basic suck it and see process will apply. A CAD drawing is available for anyone who wants to have a look. No Engineers certificate is supplied No liability is accepted I had to go to 15" alloys with this conversion. Probably not a big issue with a 1600 [factory wheels are 13"] but may be too much for a car which started with 12" wheels. I think there are legal issues going more than +2" in wheel diameter Perhaps the tyre placard could turn up missing ![]() ![]()
#14
Re: RX7 S4 Calipers
4NIK8
Posted on: 2007/5/16 18:05
no worries :)
buying them through maddat comes with an engineer report which is a bonus
#15
Re: RX7 S4 Calipers
oan878
Posted on: 2007/5/16 18:25
I need ford 5 stud on the front so it will match my hilux diff.
does anyone know how to do that.
#16
Re: RX7 S4 Calipers
DUMBO
Posted on: 2007/5/17 3:01
oan878- Mick (1200U) is getting custom hubs turned up on the lathe to suit commodore 5stud pattern.
My plan is to do the same. They will be a replicate of the 120Y hub used with the S13 Brake setup.
#17
Re: RX7 S4 Calipers
EVL-UTE
Posted on: 2007/5/17 3:17
If your interested in 5 stud, this is what I've got. Mine are commodore stud pattern, but this kit is available in ford stud pattern also. Touch on the pricey side though!! It's a kit from hoppers stoppers in melbourne.
[img align=right]http://datsun1200.com/modules/myalbum/photo.php?lid=8936&full=1[/img]
#18
Re: RX7 S4 Calipers
B210sleeper
Posted on: 2007/5/17 3:19
that starts to get messy using Rx7, Golf and 200b parts. Will it work... I suppose... I'd rather keep the parts all in 1 family, but if it works and it's what you got, then good job, that's probably harder than slapping S13 parts on he 120Y
#19
Re: RX7 S4 Calipers
1200_brute
Posted on: 2007/5/17 3:54
thanks for all the replies and help, keep em comin :)
#20
Re: RX7 S4 Calipers
B210sleeper
Posted on: 2007/5/17 7:53
all that heavy stuff adds unsprung weight too...
