« 1 2 (3) 4 »
Re: Adjustable Camber Plates, EOI
From San Jose, California
What is the inside diameter and thickness of the spherical bearing? I need to know if they will work with the VW rabbit strut inserts I'm using.
Posted on: 2007/5/17 12:35
-Daniel
From Geelong, Vic
Posted on: 2007/5/17 12:44
From Melbourne, Australia
Thanks pigdog. Yeah, typically l don't but in on someone else sale thread, but since you guys were curious. I've sold about 20 sets so far, and my original ones are still running on my ute (up in syd).
Happy to help anyone that is interested with designs etc....(i've got a new al design for my 1600 that should be ready soon, but prob more than $180!!!)...
Cheers
Andy
Posted on: 2007/5/17 12:51
From Geelong, Vic
rock1200, could you post some approx prices for say if you got 5, 10, 15 people ect
Posted on: 2007/5/17 13:00
From Burbank, CA
those are nice :)
|||\ 81 KPB310 /|||
From Adelaide
Batches of 10 @ $160 posted, 5 @ $165 posted, batches of 15 will be approx same price as 10 maybe little cheaper, not much though.
I will do final no's next week. Should be ready 2-3 wks max!
Posted on: 2007/5/17 13:16
XR6T 320rwkw
Stock 1200 Sedan
1200 Sedan, S/C a15
From Adelaide
IDA of bearing is 18mm not to sure bout thickness.
Posted on: 2007/5/17 19:45
XR6T 320rwkw
Stock 1200 Sedan
1200 Sedan, S/C a15
I measured the stud spacing on an s13 in the junkyard today. Its about 4.5 inches while the 1200 is 4.25. The studs are also nearly twice as thick. Personally, I'd be hesitant to hack up my strut towers to make these fit. Any pictures of some fitted to a 1200?
Posted on: 2007/5/18 12:42
-Daniel
From southern sydney "the shire"
so if i buy some of these they will be complete and ready to bolt in to a 120y or will i need to buy bearings ect?
Posted on: 2007/5/18 14:05
From Geelong, Vic
about the s13 having different strut top spacing to the 1200....are you sure your measuring stick was accurate
if you file the holes out to the right size to fit the studs (thats right filing not hacking) just make sure you file inwards and every thing should be right
ive got s13 camber tops i my 1200, and i had already done the filing to fit stanza top plates so they went straight in
Posted on: 2007/5/18 15:16
« 1 2 (3) 4 »
