« 1 (2) 3 »
Re: easy conversion
From Quairading, Western Australia
Just need to find a L16/L18 and 4 speed now...
Posted on: 2007/5/19 8:03
Re: easy conversion
From Geelong, Vic
yeah l20b will go in the same as an l18
Mawler1 why do you want to find a 4 speed? 5 speeds are every where
Posted on: 2007/5/19 15:22
Re: easy conversion
From Gold Coast
Arnt the L20s a litte higher than the L16/L18"s?? i cant quite remember but i think we had to modify my old mans eng monts ta mount a 2L in his 720
Posted on: 2007/5/19 15:27
Re: easy conversion
From Geelong, Vic
height wont matter for a 120y, and you just use engine mounts for the engine that was originally fitted to the crossmember
Posted on: 2007/5/20 6:18
Re: easy conversion
From Brisbane, Australia
the sump configuration is different between L18 and L20. You'd need the L18 sump and pickup, and some modifications for the dipstick to fit an L20 where an L18 was. certainly not a major problem, just don't expect it to go straight in the same as an L18. 1600 people often used to reverse the x-member (involves reorienting the LCA mounting pins) to fit L20's.
240K was only used for the C110 model Skyline in Aus. The C210 was just known as a Skyline here. So its safe to assume he meant C110 when he mentioned 240K. whether that x-member works in a 120Y and L18 is a different story. I might measure it up when I get a chance - I was going to try Stanza x-members to get the forward sump setup to suit the late L16 and L20 engines because they're less prone to oil surge on the track. Plus I'm not a huge fan of the pin mounting for the LCA that the 180B had.
Posted on: 2007/5/20 7:04
Re: easy conversion
because it's a farm hack - 100 Km/h in a paddock is fast enough
Posted on: 2007/5/20 7:11
Re: easy conversion
From Vic Bendigo
well its got the original a12 so what steps do i take to fit the l20b? do i need to change the steering at all? It has sunny struts just gone in and it does sit a bit high will the l20b bring it back down? (hope so) and if anyone has a running l20b with gear box that would be good to evan an l16 l18 would be good. Because im not sure of the condition of the l20b i have i know it needs boring out but other than that i duunno and im not real keen on paying to rebuild it.
But still if there is an a12 a14 a15 in good running order send it my way.
Posted on: 2007/5/20 10:03
Re: easy conversion
From Geelong, Vic
was definatly a 240k crossmember in the 120y....well it wasnt a 180b one any way, looked similar to a 200b one so ill take his word that it was 240k
the person im talking about i now know is grall3, so he might be able to confirm whats been done exactly
Posted on: 2007/5/21 13:04
Re: easy conversion
From bendigo victoria
hey mate who have u tryed in bendigo as there are still some laying around if u no where to chase them
Posted on: 2007/5/21 14:38
Re: easy conversion
From Vic Bendigo
i havnt actually looked for the l seires but the a series i couldnt find anywhere.
Posted on: 2007/5/21 22:44
« 1 (2) 3 »
