Re: Turbo choice
From Gold Coast
It actually works really well and as the car was built for drag racing/street i wanted the boost to come on a bit later and not run out of puff to early and as for driveability its actually good you can drive around and change under 2500 rpm and the cops dont even here it boosting.
Ive had the t and now the gt series turbos and that wasn't the power i wanted this car to make.
Posted on: 2007/5/20 4:31
Re: Turbo choice
From Wagga Wagga
if whant cheap turbo new the T2.5s are less than $300 new! there small but there not that bad. otherwise T3/4s are about $600 new.
from south africa.
Posted on: 2007/5/20 7:04
1980 Datsun 1200 Ute (WIP)
A15 Engine
5 Speed Sunny
H165 Diff
Re: Turbo choice
From campbelltown (sydney) australia
yeah ur right but theyre from south africa !!! ive seen some of the ads for these cheap turbo's, the names sound as cheesy as cheap dvd players. theres a reason they are so cheap.
Posted on: 2007/5/20 9:57
* caution, sunglasses must be worn to view my ca18det *
Re: Turbo choice
From Sunnybank, Brisbane
sorry to be a thread thief, but while your all on the subject of cheap turbos, ive been offered a high flowed t28 for $200 from a guy from work, i havent seen it yet so i dont know of the condition, im just wondering whether or not its worth buying a 2nd hand turbo now or just saving my pennys for a new disco potato?
and how do i tell if its been high flowed/wats the diff between a standard turbo
(its for a ca18det ute, as u can prolly tell i dont know all that much about turbo's atm, but im learning)
regards Jimbo
Posted on: 2007/5/20 10:47
Re: Turbo choice
From Canberra
I believe a hi-flow turbo will have had the compressor housing bored out and a larger front wheel fitted. At $200 its definately worth looking at
Posted on: 2007/5/20 11:56
Re: Turbo choice
From Gold Coast
thanks for all the oppinions guys.. my ute will ba be mainly used for strip action so the turbo not bein SUPER responsive is not a real drama.. as i dont want the turbo to run outa puff in the top end.. I had a L20 turbo in my 1600 with a T04E and it wasnt too bad ta drive.. as turboute said u can shift gears at 2500rpm and it sounds N/A!!
Its only an option at this stage, just wonderin what everyone else thinks
Posted on: 2007/5/21 13:53
« 1 (2)
