#21 Re: A series camshafts!!
Skey Posted on: 2007/3/6 14:29
Cheers Benny!!
#22 Re: A series camshafts!!
ddgonzal Posted on: 2007/3/6 16:58
The recommended compression ratio for a camshaft like that using A12GX induction is:
* for use with regular grade gasoline: 10.0:1
* for use with premium grade fuel: 9.0:1
Now the cam grinder may have his own recommendation. There is no exact science here.
You should be able to use the 9.0:1 with regular gasoline in just about any country. The aluminum head allows about 0.5 extra ratio over a similar cast iron head.
#23 Re: A series camshafts!!
g1 Posted on: 2007/3/7 4:19
Guys, i need help. Is there anyone planning to sell off an A15 modded cam. A 270 or 280deg intake will be great. I have trouble finding for one. If anybody can provide me a link where i could purchase one from my country, that will be superb..pleaseee help me guys. My DCNFed ported head and A15 block is craving for a cam. Thanks alot...
#24 Re: A series camshafts!!
prospec Posted on: 2007/5/21 12:27
Hey all im building a street/race a15 large port head big valves quad throttle boddie EFI knife edge crank 79mm pistons blah blah blah any one got any good cams they recomend? race perferably...Thanks Kyle
#25 Re: A series camshafts!!
possum1200 Posted on: 2007/5/21 12:32
gday this thread was at the top... ive got a spec sheet of the engine in my recently purchased car althought for my camshaft it only gives "cam 54/78 grind"
can anyone explain these numbers to me? also how aggressive is this cam?
#26 Re: A series camshafts!!
prospec Posted on: 2007/5/23 10:23
#27 Re: A series camshafts!!
dattoman_1000 Posted on: 2007/5/23 12:09
Didn't you ring Clive ?
#28 Re: A series camshafts!!
prospec Posted on: 2007/5/23 12:52
No not yet tomrows job just getting other peoples oppinion and are useing the gear...
#29 Re: A series camshafts!!
sycodat Posted on: 2007/7/29 16:29
I couldn't tell you (stumped )
« 1 2 (3)
