springs for stanza struts in a 1200
From perth airport
hi guys i have put stanza struts in my 1200 ute and in looks like some one has put a jack under it ( way up in the air )
i run 15 inch wheels wat springs should i buy to drop it ??????????
perth wa
Posted on: 2007/5/22 5:24
Re: springs for stanza struts in a 1200
From Canberra
I had king springs 'lows' in mine and thought it was still too high, if I did it again i'd get superlows
Posted on: 2007/5/22 5:41
From perth airport
thanks man
Posted on: 2007/5/22 5:54
From adelaide
I bought low king (crap) springs, biggest waste off money ever. They would hardly be 10% stiffer than 1200 springs. Side by side you cant feel a difference pushing down on them by hand. This means heaps of suspension travel, when you hit a bump with stanza struts (which are too long really) they bottom out heaps. So i went to the wreckers, spent the best $20 ive spent on upgrading my suspension sinse the 120y sway bar. Bought a pair of TE gemini front springs, cut them down about 3 coils from memory as they are very long, leaving ride hight approx 1" above the tyre. Result, never bottoms out, handles at least 50% better than the kings did and cost squat
Posted on: 2007/5/22 8:31
1200 restoration project moving slower than it actually is
From Geelong, Vic
200b rear springs, they are progressive...so cut the soft end
Posted on: 2007/5/22 12:01
From perth airport
so looks like chopping the spring is the best way ????
and new sway bars ???
Posted on: 2007/5/23 0:40
From Geelong, Vic
120y
Posted on: 2007/5/23 4:31
From Mandurah, Western Australia
Contact Pedders in Canningvale.
You will need the loaded spring height of the Stanza springs that are in your car.
If you dont know how to measure this they can instruct you on how.
Tell them ride hight and stiffness that you want and they will calculate and sudgest several springs.
Eliminates all the trial and error - Good Luck
Maybe you should have a look at my coupe. Im going through this process at the moment. Stanza struts with a CA18DET engine.
Posted on: 2007/5/23 5:12
From perth airport
thanks dude ill have too take my ute in and tell em too drop it :)
you got some pic of yous ?
Posted on: 2007/5/23 5:39
