Re: turbo setup question?
From NSW, Australia
I don't know the finer details on suck through, but on Blow through. The brass one collapses under boost (squashes flat)
Like a coke can. crushes
Posted on: 2007/5/22 0:11
Cheers,
Big D
Quadruple Crown in 1980, the year my 1200 was Built.
From adelaide
yea ive always used the black plastic ones, ive always used webbers from unleaded falcons as there the same bolt/hat pattern, bigger throttles and have a vent from carby lid to float bowl for boost reference and have the black floats. Hope that makes sense. Also scour the wreckers and find an lpg hat to use, makes it easier if you have the bonnet clearance, heaps of gas xfs around!
Posted on: 2007/5/22 8:39
1200 restoration project moving slower than it actually is
From Brisvegas, oz
do you have any pics of it
Posted on: 2007/5/22 9:54
www.camerasplus.com.au
From In front, and pulling away.Sometimes around Sydney....ish!
What was I thinking? You are right BigD, use the plastic NOT the brass! It was late and I was umm tired.
Also I used to use a 32/36 DGV weber and remove the choke shafts and butterflys to reduce the restriction. I would just use the choke cable to pull the idle up to warm it up.
Posted on: 2007/5/22 10:22
Lifes good when your on BOOST!
From sydney
what are you's trying to do to the turbo???????
Posted on: 2007/5/22 10:39
From Canberra
Posted on: 2007/5/23 10:46
From Gold Coast
Thats a pretty neat setup.. pretty fair price too!!
Posted on: 2007/5/23 12:43
« 1 (2)
