brand new discs, where can i get em
From young
Hi im jus wundrn wer can i get sum brand new discs 2 fit stanza/120y struts nd how much$$$ , also how much work is it to get an r31 lsd disk brake rear end in the 1200 ute any info is much appreciated THANX Appsy1
Posted on: 2007/5/23 2:57
1200ute jelly bean mags
twin 40mm dellortos
Re: brand new discs, where can i get em
From Geelong, Vic
supercheap, autopro, autobarn, clutch and brake shops....all should be able to get you new discs
and for the diff, $500-$1000 to get it cut down and newmounts put on....depends what you can do yourself
Posted on: 2007/5/23 4:04
From Brisvegas, oz
super cheap has slotted discs for $99 at the moment
Posted on: 2007/5/23 5:29
www.camerasplus.com.au
From young
THANX for the reply pigdog my dad can cut nd balance diffs nd tailshafts nd stuff is that the only part that will cost muny to install the diff?? apart from buying the diff Appsy1
twin 40mm dellortos
From Sunny Coast, QLD
They had new slotted disks for a 120Y on ebay a few days ago. I think they were around $60 but I dont really remember.
Posted on: 2007/5/23 6:24
From Brisvegas, oz
the ones on ebay had been used like twice and still went for $86 plus postage, you would have been crazy to pay this when for pasiclly the same price you could have got the exact same but brand new from supercheap.
Posted on: 2007/5/23 12:10
From Geelong, Vic
if you can cut and straighten the diff then the housing part should be right...doubt you would have the facilitys to cut and respline the axles though
mounts should be fairly easy...its only leaves
Posted on: 2007/5/23 12:17
