Re: factory turbo motor into 1000 sedan
From Coondle, WA Australia
I saw some of those photos of a ca 18det into lagwagons 1000. From memory, its about $2500 for a front cut silvia. You could do a direct transplant touching nothing and I reckon it would come out about the same. as the a15 jobby.
In my guesstimation of 15 turbo job, i reckoned
rebuild a15 - $1000
computer - $1000
turbo - $800
custom pipe work to make it fit - $500
misc - $800
= $4100
plus everything else!!
The a15 was planning on going efi, crank angle sensors, rollers, double valve springs etc, the whole bit. so basically a modern efi motor, but with the heritage and simplicty of transplant.
But with hp figures of about 170hp at the flywheel for a standard ca18det, i would think that you wouldnt get that sort of hp from the a15 without serious mods.
Is my logic logical??
Posted on: 2007/5/26 4:39
EARTH FIRST! - We can mine the other planets later...'
'69 Blue 4 door Project Daisy (http://www.datsun1000.com/TopicView.asp?TopicID=668)
(https://pcmhacking.net/forums/viewtopic.php?f=15&t=5640)
(http://mx5cartalk.com/forum/viewtopic.php...
Subject Poster Date
     factory turbo motor into 1000 sedan reuby_tuesday 2007/5/25 22:43
       Re: factory turbo motor into 1000 sedan Ianey 2007/5/25 23:08
         Re: factory turbo motor into 1000 sedan Ianey 2007/5/25 23:12
           Re: factory turbo motor into 1000 sedan sidedraught 2007/5/26 1:02
             Re: factory turbo motor into 1000 sedan dazzasute 2007/5/26 3:57
               Re: factory turbo motor into 1000 sedan reuby_tuesday 2007/5/26 4:39
                 Re: factory turbo motor into 1000 sedan Ianey 2007/5/26 4:47
                   Re: factory turbo motor into 1000 sedan reuby_tuesday 2007/5/26 4:54
                     Re: factory turbo motor into 1000 sedan sikdatto1200 2007/5/26 7:54
                       Re: factory turbo motor into 1000 sedan reuby_tuesday 2007/5/27 0:21
                         Re: factory turbo motor into 1000 sedan dattoman_1000 2007/5/27 3:35
                           Re: factory turbo motor into 1000 sedan Tyrie 2007/5/27 5:59
                             Re: factory turbo motor into 1000 sedan reuby_tuesday 2007/5/27 7:57
                               Re: factory turbo motor into 1000 sedan dattoman_1000 2007/5/27 11:27
                                 Re: factory turbo motor into 1000 sedan reuby_tuesday 2007/5/28 3:46
