Re: factory turbo motor into 1000 sedan
From Perth
Well you wouldn't use the 60a box with the CA anyway
You'd use the 5 speed that comes with it like I'll be doing
I've had long talks with rego dept about the CA conversion into my 1000 coupe
They were not at all keen
Once I explained I wanted a later model efi engine in RWD and the fact the only way you will get this thru Nissan is 1.8 or 2.0 they softened alittle
But they were against any form of boost
However
I'm still going to go ahead with my CA turbo setup
However my CA is a SOHC not a big head DOHC and after explaining this to them they gave me verbal approval but won't put anything on paper till they see it in the car
You will need suitable suspension , brake and chassis mods to get anywhere near rego plates
This is my theory (for my own car)
CA18ET
Factory computer
Factory 5 speed that came with the CA
Custom tailshaft
R31 Pintara diff with disc rear (R32 2 pots actually on vented disc)
4 link rear setup (no more leaves)
Front brakes will be my hubs (in alloy) but adapted to 294mm WRX 2 piece discs
AP 4 pot calipers from MGF Trophy.
Balance bar and twin master cylinders
Hydraulic clutch setup (hidden under dash)
Chassis strengthening and seem welding
Coilover front setup
Thats just for starters
If you want a cheap HP solution jump on the turbo manifold bandwagon and go that way with an A series
I will also be doing this for my wagon with old race motor.
Posted on: 2007/5/27 3:35
Subject Poster Date
     factory turbo motor into 1000 sedan reuby_tuesday 2007/5/25 22:43
       Re: factory turbo motor into 1000 sedan Ianey 2007/5/25 23:08
         Re: factory turbo motor into 1000 sedan Ianey 2007/5/25 23:12
           Re: factory turbo motor into 1000 sedan sidedraught 2007/5/26 1:02
             Re: factory turbo motor into 1000 sedan dazzasute 2007/5/26 3:57
               Re: factory turbo motor into 1000 sedan reuby_tuesday 2007/5/26 4:39
                 Re: factory turbo motor into 1000 sedan Ianey 2007/5/26 4:47
                   Re: factory turbo motor into 1000 sedan reuby_tuesday 2007/5/26 4:54
                     Re: factory turbo motor into 1000 sedan sikdatto1200 2007/5/26 7:54
                       Re: factory turbo motor into 1000 sedan reuby_tuesday 2007/5/27 0:21
                         Re: factory turbo motor into 1000 sedan dattoman_1000 2007/5/27 3:35
                           Re: factory turbo motor into 1000 sedan Tyrie 2007/5/27 5:59
                             Re: factory turbo motor into 1000 sedan reuby_tuesday 2007/5/27 7:57
                               Re: factory turbo motor into 1000 sedan dattoman_1000 2007/5/27 11:27
                                 Re: factory turbo motor into 1000 sedan reuby_tuesday 2007/5/28 3:46
