Re: timing cover removal
Cranking it is fine to do. Its also easy enough just to put the car in gear and release the handbrake and roll the car to undo it. Doesnt take much to crack it.
You will need to drop the sump a little to remove the timing cover, otherwise you will crack the cover prying it when it cant go.
Posted on: 2007/5/30 7:59
Subject Poster Date
     timing cover removal reuby_tuesday 2007/5/30 1:02
       Re: timing cover removal Tyrie 2007/5/30 4:48
       Re: timing cover removal sundat1200 2007/5/30 5:05
         Re: timing cover removal Ronald 2007/5/30 5:35
           Re: timing cover removal Freak 2007/5/30 5:48
           Re: timing cover removal Tyrie 2007/5/30 5:53
             Re: timing cover removal datrat_dave 2007/5/30 6:44
               Re: timing cover removal phunkdoktaspok 2007/5/30 7:59
               Re: timing cover removal WhiteSedan 2007/5/30 8:01
             Re: timing cover removal Ronald 2007/5/30 8:40
