Browsing this Thread:
1 Anonymous Users
Turbo EFI Set up |
From Perth
I have a T28 turbo and manifold Ally inlet (round port) manifold with 60mm throttle body to suit A series, Injectors adjustable fuel reg Subaru water air intercooler and 12v water pump Stinger ECU and Harness to suit, elec dizzy modded for turbo + other stuff I have no time to put it my Ute The wiring will need some sorting out I have the full stinger manual I want around $1500 for all of it I don
Posted on: 2007/5/30 3:21
Re: A15 + Turbo EFI Set up |
From NSW, Australia
Is the exhaust manafold round port too or Oval port ?? also has it got a J pipe or its a proper made manafold (straight to the turbo) Interested to see pic's
Posted on: 2007/5/30 5:34
Cheers, Big D Quadruple Crown in 1980, the year my 1200 was Built.
From Canberra
exhaust will be square port
Posted on: 2007/5/30 5:40
From Perth
Its a 1 piece manifold made from steam pipe elbows the turbo bolts to it The round port head was on the engine, it must be off a 120y
Posted on: 2007/5/30 9:29
From NSW, Australia
PM sent
Posted on: 2007/5/30 22:52
Turbo EFI Set up |
From Perth
Pctures added more can be emailed
Posted on: 2007/6/28 2:33
Re: Turbo EFI Set up |
Quite a regular
From Adelaide, Australia
Hmmm very intersting.
The dizzy "modified for turbo" meaning what - has the timing map for it been changed?
Also, is there a fuel pump and surge tank I see there?
I'd would like to see more pics please, PM me if you could, I'm very interested.
Posted on: 2007/6/28 2:44
From Adelaide, SA
A dizzy modified for turbo usually means the mechanical and vacuum advance has been disabled by locking the two shafts together.
Posted on: 2007/6/28 3:40
From Perth
Yeah its locked but I was going to try and use the stinger to control timing but never got aroud to doing it All of this gear was in a running Datto 1000 I have all of the gear here still but will separate. Im going to put turbo and stinger on Ebay later
Posted on: 2007/6/28 4:32
Quite a regular
So the Stinger is tuned for a 1000 and has all the sensors and plugs to suit injectors etc? Does it run well?
We are very interested in this if you are willing to ship the lot.
Posted on: 2007/6/28 4:44
