« 1 ... 7 8 9 (10) 11 12 13 »
Re: Bulk buy for turbo manifolds
From Brisvegas, oz
shipping to the states will cost about $30 more in aussie money thats by sea mail and $70 more by air mail. Thats a rough estimate cos i just checked it on australia post and that was estimating about 5kgs
Posted on: 2007/6/1 7:42
www.camerasplus.com.au
From Newscastle, Australia
how much again and does it include turbo and engine flange?
Posted on: 2007/6/1 7:47
Dont die wondering.....
just a querie on the pipe that the welder will be using ... my understanding is that steam pipe is a schedule 40 grade pipe which has a higher bursting capacity than mild steel. you can get all the bends and the likes in both mild and sched40, they even look the same as the cross sectional wall thickness is the same ....
how much pressure is the exhaust manifold likely to be under ??
also on a side note about the manifolds, will the fabricator be cleaning up the welds on the outside to give a nice smooth finish and the inside to give a nice smooth travel for the gas ??
and yes i'm interested at this point
Posted on: 2007/6/1 8:06
From Burbank, CA
pm me with info on how to pay... been waiting a long time for a turbo mani.
Posted on: 2007/6/1 8:36
|||\ 81 KPB310 /|||
From Brisvegas, oz
the price will be 250 delivered in australia with flanges welded on,
boof the welding guy will be using a tig welder hes not some dodgy guy from a backyard setup he is a proffesional welder if they exist ive seen much of his work and its nice.i showed the pictures of th exhaust that we all like and he said it will be the same but designed to sit a bit closer to the a series, when i requested the pipiing he asked weather i wanted stainless or or mild steel, i said mild steel, he said they can buy mandrel bend steem pipiing made from mild steel which he said was about 4mm thick. and as for the pressure well i would say it would handle as much as you could give it for an a series i think thats all the questions answered if not give me a calll on 0402859342 it might be easier to explain.as i said before i will be posting pics of the manifold prior to taking money of people so they know what sort of quality there getting, cos i dont want people getting the item and its not what they wanted.
1.frankthedolphintrainer x2
2.dattoman_1000 x 2
3.dog160 x 1
4.sidedraught x 1
5.pager x 1
6. ianey x 1
7. minitruckin x 1
8. b210 sleeper x 1
b210 sleeper ill get a deposit closer to the date just watch this space for any new info
o and when we were trial fitting today i found it good that you can fit the turbo and pipiing without it getting in that way of the radiator water pipe.(i thought it might have to be cut) so thats another plus.
Posted on: 2007/6/1 8:54
From Perth
Have you tried it with a twin weber manifold to ensure clearance ?
I know you tried a stock one
But what about a flash one ?
Posted on: 2007/6/1 10:26
From Brisvegas, oz
unfortunatly no i havnt checked the clearance for a twin weber i dont have access to one unless someone close or someone would like to post one to me for a few weeks and ill post it back. or maybe someone can take a good photo of one and get as many measurements for it as possible.
Posted on: 2007/6/1 11:17
these are a couple of the Aseries twin carb manifolds .... stewart wilkins top one and redline bottom one
and yes stick me in for 1 x manifold
2.dattoman_1000 x 2
3.dog160 x 1
4.sidedraught x 1
5.pager x 1
6. ianey x 1
7. minitruckin x 1
8. b210 sleeper x 1
9. boofhead x 1
Posted on: 2007/6/1 11:58
From Perth
I have the top one
And a modified top one too
If it fits that I'll be happy
Posted on: 2007/6/1 12:04
i have the bottom one which needed a little convincing with the angle grinder to fit with the extractors i'm running on my a series.
Posted on: 2007/6/1 12:09
