#1 sedan 6 point roll cage
stooey47 Posted on: 2003/3/6 9:47
FOR SALE
Bolt-in roll cage for 1200 sedan. Made from seamless cold-drawn steel tube as per CAMS specifications, including provision for harness bolts (not bolted together with fence-connectors). Tube thickness is 3mm with a 40mm main hoop and the rest is 35mm. Weight is approx. 30kgs
$650
stuart
ah. 03 98789027
#2 Re: sedan 6 point roll cage
stooey47 Posted on: 2003/3/12 6:33
c'mon,
someone must be building up a sedan and need a cage. it unfortunately only fits a sedan, being the reason i am selling it (i have a coupe).
it's a 6 point cage, and all the specs are in my previous post.
$650ono
stuart
ah. 98789027
email. stooey47@hotmail.com
#3 Re: sedan 6 point roll cage
1200rallycar Posted on: 2003/3/12 8:05
would this fit my 2dr sedan???
actually i think the 2dr has a lower roof like the coupe doesnt it?
#4 Re: sedan 6 point roll cage
flyby Posted on: 2003/3/12 9:46
Yep I think so...
I would happliy take it if you were near by, too much of a hassle to get a cage up...
#5 Re: sedan 6 point roll cage
1200rallycar Posted on: 2003/3/12 11:22
its bolt in, you can diasssemble it to a box size which would fit the main hoop, and put it back together again
#6 Re: sedan 6 point roll cage
stooey47 Posted on: 2003/3/12 11:56
it would have to be a big box, height and width of sedan. but it could be done.
1200rallycar, if you want to measure it up for your 2 door, let me know. i'm in blackburn
stuart
#7 Re: sedan 6 point roll cage
NoPsi Posted on: 2003/3/13 5:29
I thought this one was sold!?!? Was it advertised on rally.com.au? I rang last week and was told it was snapped up. Now I have spent the bloody money on other stuff. Or is this a different Stuart and sedan cage??
Craig
#8 Re: sedan 6 point roll cage
stooey47 Posted on: 2003/3/13 7:19
it's the same cage, but a different stuart.
i bought it, but then found that it doesn't fit my coupe.
if your interested, give me a call or email.
stuart schoof
98789027
#9 Re: sedan 6 point roll cage
muke Posted on: 2003/3/13 15:18
where bouts do u live...and will it fit tha 4 door
#10 Re: sedan 6 point roll cage
NoPsi Posted on: 2003/3/14 4:34
Stooey,
You have mail.
Craig
(1) 2 3 »
