Auto Sparky's
From Warwick, QLD
Hey guys who her is an auto sparky???
cheers
Damo
Posted on: 2003/3/14 12:32
Drive It Like You Stole It
Every Car Has 500hp In The Wet
Team NEW SKOOL
Re: Auto Sparky's
From Canberra, Australia
I'm not gonna dob him in....
Posted on: 2003/3/14 12:50
1971 Datsun 1200 Coupe
A15 Engine. Holley G180 (32/36 Weber). extractors and 2 inch exhaust.
Standard 1200 4 speed with lightened fly wheel and HD clutch
Stanza front struts and brakes.
15x6 CSA Wheels with 195/50 rubber.
Re: Auto Sparky's
From Warwick, QLD
phunkdoctaspok your an auto sparky aren't you???? I need a little advice
cheers
Damo
Posted on: 2003/3/14 13:13
Team NEW SKOOL
Re: Auto Sparky's
From Brisbane
Demo check ur PM
Posted on: 2003/3/14 13:20
OLD SkOOL POWeR!!! [color=CC0000]"with the sound & smell of twin 40s at full throttle!!!" [/
Re: Auto Sparky's
From Warwick, QLD
is changing the wiring from an external regulated alternator, to an internally regulated one, something you can do ya self, or is it a job for a qualified auto sparky???
Cheers
Damo
Posted on: 2003/3/15 13:10
Team NEW SKOOL
Re: Auto Sparky's
It is very easy to do yourself. Generally there is one wire from the alternator to the battery. Much simpler than the original setup. Even a regular three-wire setup is simple to wire.
See Alternator for discussion of Ford Falcon EA swap.
Size comparo - stock alt vs EA
EA mounting diagram
GM alternator swap
In the US the GM 'single wire" alternator used to be the popular swap, since they were the first to have an internal regulator, were commonly available (read, relatively inexpensive) and for those stymied by three wires (BAT, IGN and idiot light), the "one wire" promised simplicity.
The GM alternator is available in versions for 50 amps to over 100 amps.
Datsun 311s.org singlewire: pics, info.
mightymo.org: one-wire swap, troubleshooting, testing, rebuilding alternator
Self-energizing regulator details
Better alternatives?
Of course, lighter is better, so no point in loading up your 1200 with extra weight if you don't need it. Perhaps a high-efficiency "mini" alternator from a newer Subaru or Toyota would be the way to go: extra amps, but not extra weight.
Posted on: 2003/3/15 16:55
Re: Auto Sparky's
Sorry I am a bit late to answer this,
Demojob the answer to your question of who its a job for, really depends on how smart you are! lol.
But really internal reg alternators only need 2 and sometimes 3 wires.
1 thick one from battery to alt
1 thin from alt to the dash charge light,
and sometimes 1 ignition 12volt supply to the alt.
I think if you look in the links ddgonzal has supplied it will take you to a previous discussion of this. quote" i think"
Posted on: 2003/3/16 10:01
Re: Auto Sparky's
From Warwick, QLD
kewl, thanks for that guys,
ummmmm why does the external regulator have so many wires goin to it?? What wires do I need to substitiute and hook up to where??? whats the colour coding of thiese wires and purpose.
cheers
Damo
Posted on: 2003/3/17 12:05
Team NEW SKOOL
Re: Auto Sparky's
From Warwick, QLD
it's cool fellas, I found the older posts on wiring alternators, thanks
Posted on: 2003/3/17 12:39
Team NEW SKOOL
