#1 Achieving 150-160 HP?
1200_hotrod Posted on: 2003/3/14 12:42
any one with ideas on how to get 150-160 hps from a stock a12 block with a15 head i neeeeed help on whoopin sum honda ass's..and i was told a needed a bigger diff..if i was to use that kind of horses..thanks...
#2 Re: Achieving 150-160 HP?
Demojob Posted on: 2003/3/14 13:19
go with a Ute diff, they are a bit hard to come by but well worth it, to get alot of horses, just bore out the cylinders and get a gx head and do some extesive work on it, or buy my gx head I have for sale, it's had alot of work done to it,
and go with twin webbers, and a NOS system
cheers damo
#3 Re: Achieving 150-160 HP?
1200_hotrod Posted on: 2003/3/14 13:26
thanks man but i don't now what a ute is here in the us...if i was to buy your head it'll cost me a #### load to mail it here to the states though...
#4 Re: Achieving 150-160 HP?
1200rallycar Posted on: 2003/3/14 14:52
how much you want for ya head???
found it never mind!
#5 Re: Achieving 150-160 HP?
ddgonzal Posted on: 2003/3/14 18:26
To get that kind of HP out of 1200ccs, you're going to have to rev it very high, with all that entails. The newer Hondas are factory designed to rev high with have variable cams etc. The advantage your 1200 will have is far lower weight (except for the original Civic, which is just a little heavier than a 1200).
Rather than build up an A12, it would be cheaper to fit an L18 or KA24.
#6 Re: Achieving 150-160 HP?
1200_hotrod Posted on: 2003/3/14 20:24
thanks for the info man..you guys r the best...
#7 Re: Achieving 150-160 HP?
Brent Posted on: 2003/3/14 20:50
I've got the HP your after out of a A12A, with great torque figures as well.
The cost approx NZD20k (USD10k), so hope you have a reasonable budget.
#8 Re: Achieving 150-160 HP?
1200_hotrod Posted on: 2003/3/14 20:57
wow thats a budget...i ain't got that kind of cash just lying around...thanks man..my whole goal was to get more than the weak stock 69 hp..for like freeway driving and everyday driver thing...cuzz it has to rev so high doing 65 mph to about 75 mph....feel sorry for the thing..
#9 Re: Achieving 150-160 HP?
ddgonzal Posted on: 2003/3/14 21:53
1200_hotrod, since you are in the US, I highly recommend buying an entire 79-82 210 (B310) car for $250 bucks or so, and put the engine, 5-speed and driveshaft/tailshaft in your B110. B310 wagons usually have the A15, sedan/coupes the A14.
The 5-speed will lower the revs on the freeway, less noisy too.
Not sure if this'll beat the Hondas you referred to but ... easy to swap in. See the Tech Section article What's the best engine to put into a 1200?.
