stumpy gearbox --- H165 diff.. wat tailshaft??
From Adelaide
hey guys
im putting a ca18det in my 1200 ute and im using a stumpy gearbox with a H165 diff..
wat tailshaft would i use? and wat end would i need to shortern flange or yoke
Posted on: 2007/6/6 11:38
Re: stumpy gearbox --- H165 diff.. wat tailshaft??
From Warwick, QLD
Use a bluey wagon tailshaft, it's a one piece shaft mine had to be shortened about 33mm from memory, but it's bolts up to the diff perfectly and it goes into the gearbox.
Posted on: 2007/6/6 11:49
Drive It Like You Stole It
Every Car Has 500hp In The Wet
Team NEW SKOOL
From Geelong, Vic
series 1 or 2 bluebird tailshaft, sedan ones are one peice too
or a stanza one, from a stanza with a h165 obviously
Posted on: 2007/6/6 12:52
From sydney australia
the stanza one wont work,as the output splines are different.use the bluebird shaft &
have it shortened, & through in some new uni's at the same time.
Posted on: 2007/6/7 8:55
From Adelaide
Wat year bluebird??
sum guy said below of a wagon? is there a differenece between wagon and sedan?
hmm also..
wat year do i get the bel housing off? people are saying series 3.. but i looked the other day and they say nuthing bout series 1 2 3 on the plates.. so how can i tell?
cheers
Posted on: 2007/6/7 9:04
From SE Melbourne
Series 3 bluebird housing will have an ID number with "CA" in it on the side of the gearbox like this:
Series 1 & 2 Bluebird don't have a CA motor in them, they have a L series motor.
L series and CA series tailshafts are the same, but bellhousings are different.
Posted on: 2007/6/7 10:22
Mildman, Datsunless
From Geelong, Vic
why wont a stanza one work, all L series outputs should be the same
Posted on: 2007/6/7 10:33
From SE Melbourne
Stanza would indeed work too (any L series will slot into a stumpy 5 speed) - I was just answering the Series 1/2/3 Q, figured you had the Stanza gear covered pigdog!
Pity I missed meeting you (by piking on the GOR cruise) by the way.....
Posted on: 2007/6/7 10:39
Mildman, Datsunless
From Geelong, Vic
meeting me, or my car
werent you at the lilydale cruise?
i was there with my car
Posted on: 2007/6/7 10:46
From Adelaide
i need the bellhousing for a ca18det.. so wont i need the series 3 one??
thnks mildman and pigga
