Vanette Diff
From Warwick, QLD
Hey any of you guys use a vanette diff(H190)????
If so is it better then the ute diff?? As I'm debating whether to get one to correct the weirdness of having my front wheels sticking out, cuz of my stanza struts i installed.
Cheers
Damo
Posted on: 2003/3/14 11:11
Drive It Like You Stole It
Every Car Has 500hp In The Wet
Team NEW SKOOL
Re: Vanette Diff
From Canberra, Australia
How much do your wheels stick out?
Have you got a pic?
Just some mild flaring made mine fine.
Posted on: 2003/3/14 11:40
1971 Datsun 1200 Coupe
A15 Engine. Holley G180 (32/36 Weber). extractors and 2 inch exhaust.
Standard 1200 4 speed with lightened fly wheel and HD clutch
Stanza front struts and brakes.
15x6 CSA Wheels with 195/50 rubber.
Re: Vanette Diff
From sydney australia
i've seen a h190 in a 1200 coupe,but it increases the rear track by 50 mm.you just have to move the rear spring perches.you can get steel 4.11's or alloy 4.6's.you can either use front wheel drive offset wheels,or flare the guards.the coupe at datsun1200.com/modules/myalbum/photo.php?lid=948 has the same width housing,but a h165,if you look carefully you'll see the mags are front wheel offset.the front wheels are only on there for the photo,thats the wheel from the left rear on the front.
Posted on: 2003/3/14 11:42
Re: Vanette Diff
From Warwick, QLD
Sorry lobster I don't have pics my wheels don't stick out that much, just a little noticable, I'm getting flares for the front, I don't know if it will be very noticable then.\
I've got a set of front wheel drive wheels 16x7's :)
As soon as my coupe is back on the road after I've finished everything to it, I'll take pis of it, for all
Cheers
Damo
PS Should I really change from my ute diff, or just leave it as is???
Posted on: 2003/3/14 11:51
Team NEW SKOOL
Re: Vanette Diff
From Melbourne, Australia
i think h190 is 90mm wider actually
it has fatter axles and housing ect, ect but centres and brakes are interchangable with h165 diffs
Posted on: 2003/3/14 14:56
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
