« 1 (2)
Re: Radiator Getting Too Hot!!
From South Africa, Bloemfontein
Save yourself the trouble and recore the radiator with a heavy duty 3 core one.
I did it and never looked back.
Posted on: 2007/6/6 7:25
1977 Datsun 1200GX
From Indiana, USA
I called a radiator shop and they said they could rod it for 70 bucks. Not too shabby. I did ask him about recore-ing the radiator but he recommended just rodding it.
Posted on: 2007/6/7 17:12
From Burbank, CA
you only need to recore if the rodding fails or you want to have a really good radiator, you live where it's hot, a denser core wouldn't hurt but it will cost a bit... maybe $200 total instead of $70.
Posted on: 2007/6/7 18:58
|||\ 81 KPB310 /|||
Don't bother to replace the radiator before you test it! Make sure it's bad first.
Do this simple test: take off the lower hose of the radiator. Block it with your hand, and fill the radiator with plain water. Take your hand off and the water should gush out in as big a stream as the lower opening. If it runs out in a smaller stream, the radiator has blockage inside and should be replaced or repaired.
Also, remember that a brand-new aluminum radiator is only $43 USD, but requires a bit of fitting.
wiki - Radiator
I do have a new weber 32/36 fitted as well. Would that have anything to do with it?
Nope.
A common cause of overheating is changing the coolant. With the A-series it is difficult to fill it fully. After a while of driving, when it reaches full temp the air will bleed off, so be sure to refill it after a full warm-up.
Posted on: 2007/6/8 2:20
« 1 (2)
