Re: valve resizing
From Christchurch NZ
reuby_tuesday wrote:
just a slight deviation, but still relevant
Will a turboed motor benefit the same as a NA motor from porting?
I was under the impression that the quicker/more that you get it in and out the better.
Hell yeah forced motors love porting.
Remember that boost pressure is only a measure of the resistance to the flow between the pump and the head of the valve.
If you reduce the impeadence to the flow, (ie better porting, bigger valves) then more volume of air can enter the cylinder, with less boost pressure being created. Less pressure=less heat=greater charge density=MORE POWER
Some say that too big a ports can increase lag, less of an issue though with a correctly sized turbo. I don't think this would be an issue though with the port volume increases that can be acheived with an A series motor. Especially if the porting is done by a pro, who is working to increase the flow.
Posted on: 2007/6/9 23:39
Forced Induction!
Subject Poster Date
     valve resizing picko 2007/6/8 13:29
       Re: valve resizing killer1200 2007/6/8 18:17
         Re: valve resizing picko 2007/6/9 0:36
           Re: valve resizing reuby_tuesday 2007/6/9 18:41
             Re: valve resizing A14force 2007/6/9 23:39
