no probs sikdatto - if it pulls around 20 inHG on your guage at idle then you SHOULD be right regarding the ecu map selection - I'd still have a look to see if the ecu is using the 0-5v as a reference for selecting load zones, I've seen plenty of tps sensors on engines that are only using the MAP, and I always just ran off MAP till I put the big cam in and had to run a TPS to tune the bloody thing.
I would never put a new cam in without doing the precise and fiddly thing of dial guage/degree wheel checking. You just dont know what you've got otherwise, plus you dont know how moving the cam later on will affect performance/piston-valve clearance etc. Also like I said previously the cam data always seems to differ by some amount when you get the cam into the car. I think you'll find your inlets arent opening the full 485thou (rocker wipe pattern/lash pads and rocker clearance can affect this, and it also affects timing data to a large degree). You'll notice a big difference if you're out by more than about 4 degrees in the timing, generally, I found with the stock L20b cam that RETARD will make the car doughy and slow to boost, too much ADVANCE will feel the SAME BUT you'll find it makes heaps of boost very quickly (on the guage!) but the car doesnt go anywhere (i'd say its due to the exhaust opening earlier which puts a lot of heat to the turbine, spools the turbo well, but the inlet valve is closing too early to allow it all in, combined with a little inlet reversion past the inlet valve because it opens too early while the piston is rising on the exhaust stroke)
You should have some adjustment on your stock cam gear, 1 2 and 3, the other holes that allow you to advance the cam (if its stock nissan), they can get you very close for dialling in a cam (each hole will advance the cam 4 crankshaft degrees) although in order to do this properly you'd need to measure the valve lift off the spring retainer with a solidly mounted dial guage and put a degree wheel on the crank pulley, then turn it over by hand and check the timing figures against the data you have for the cam - they might have "inlet lift at top dead centre 60thou" and if yours is 40thou you know that its retarded - if you keep turning it and find it reaches 60thou at 10 degrees AFTER TDC the cam is 10 degrees retarded, with your stock cam sprocket that'd mean you'd go back 2 holes, or 8 degrees to get it close to 10 and check it again (but if your're already on hole 1, the starting hole, you cant go back, but you can retard the whole sprocket 1 TOOTH on the chain which is 18 CRANK degrees, then ADVANCE the cam the 2 holes to advance it 8 degrees, making 10 degrees total RETARD at the crank so it matches the timing data) Its pretty involved for most people and requires patience and precision.
A more wild turbo grind would require a larger turbo, really, its all about where you want your power band. The close to stock exhaust profile of your cam would be there to provide solid, high velocity flow to the turbo to help it spool at low revs and to reduce the overlap so the exhaust backpressure from your small turbo doesnt come back into the cylinder during overlap and upset the inlet cycle (a typical 'turbo' grind) - basically a cam with lots of lift but short duration and wide lobe centres that will make lots of torque over a wide band, in an L20b wont make much power over 5000rpm, the torque peak will be around 3000, so you match the turbo to come on song before(preferably, if you can) the torque peak so you you put boost into the engine at the RPM it is most able to take in more air (this would be your situation). Then if you want more power you chuck in more boost, which wont be as much as a higher revving engine due to combustion control at the lower engine speeds (higher speed engines inherently have better knock resistance due to faster rate of combustion).
If you want to make more power than that allows you you'll have to make the torque at a faster rate, by making it at a higher rev, which means a cam that can breathe at higher revs, and this starts becoming a large naturally aspirated cam with late closing inlet to cram in boost at high revs and narrower lobe centres for overlap to scavenge the cylinder of exhaust gas and make use of the LARGER turbo you'll use which has less exhaust restriction because of its wheel/housing size. This combo becomes laggy and peaky, but more efficient at high revs.
Cams are pretty cool things, and the one thing us L series boys lack is valve area, so capitalise on knowing about cams so we can beat as many mulitvalvers as we can before they get wise
