(1) 2 3 »
distributor for race engine
Can anyone tell me what distributor to use in the following A12 engine.?
Bored .75mm over valve reliefs, all balanced, 10 to 1 comp, gx head, double valve springs, race cam (not sure what grind), twin 40m webers.
It is going into a class 3 off road race car
cheers
dazzler from australia
Posted on: 2003/3/14 11:29
Re: distributor for race engine
From Mudgee NSW Australia
Hi dazzler I used a modified N13 pulsar electric dizzy in my A14 race engine Jeff taylor at JTS is the man to speek to he did mine ready to bolt in. located in sydney Ph 02-96238826
tell him andrew denniss sent you he is a good guy and should look after you
Cheers Andrew
Posted on: 2003/3/14 13:07
Thanx ca18det_man
what sort of power did you get out of yours and how hard will/can you rev it before it goes boom
cheers
dazzler
Posted on: 2003/3/14 22:24
From Tassie, Australia
Andrew, how hard would this process (converting to electronic ignition) be to do yourself? Do you just have to change over gears or something??
I have just bought a rally car and I want to run electronic ignition in the A12 motor I am going to build for it.
Cheers,
Simon
Posted on: 2003/3/15 10:11
From sydney australia
hi andrew,was that an n13 or an n12,because i've used n12's but they're becoming harder to find,so maybe the n13 is usable.to mr nismo_4,glad to see ya back,i second andrews suggestion,call jeff taylor,he can probably supply one to you easier than hunting one up yourself.
Posted on: 2003/3/15 11:08
From Melbourne, Australia
if i remeber correctly lobsters got pics of how to convert the n13 to use on an a-series
LOBSTER???
Posted on: 2003/3/15 11:18
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From Warwick, QLD
hey mr nismo
Crow Cams do a kit it's called the fireball, it drops straight in (after you pull the guts outta ya dizzy, it drops in and wires up, it's a high powered one as you get a box to help run the elect ignition. Except sells for bout $250 I've been told they are excellent.
Cheers
Damo
Posted on: 2003/3/15 13:40
Drive It Like You Stole It
Every Car Has 500hp In The Wet
Team NEW SKOOL
jaycar does a DIY kit for $70 they have an internet site which describes it a little
http://www1.jaycar.com.au/productResults.asp?FORM=KEYWORD
Posted on: 2003/3/15 13:41
1200 Coupe Rallycar
hey i just checked out the link on the programable ignition, from the supplier, it sounds bloody good!!!
someone please tell me whether this is a good purchase or not?
i like the idea of being able to set max rpm too!
would the main features of this thing be intergrated into the computer i buy for the injection therefore making it useless?
Posted on: 2003/3/15 13:50
1200 Coupe Rallycar
Sure, though depends on what you want.
Some injection computers include ignition control, others don't.
If you want the programmable setup, you won't get that from the stock electronic dizzy.
If you just want the extra reliability, hp and easier starting of electronic ignitiion, it might be cheaper to convert the Pulsar ignition. discussion. In the US using the B210 or 210 electronic distributor is the cheapest way to go, and it has a bigger cap. discussion.
To dig up more details, use the search box on the left, look for:
electronic dizzy
The trick is ... in the results list, click "Show all results".
Posted on: 2003/3/15 16:47
(1) 2 3 »
