Re: dato ute 12a conversion
From Warwick, QLD
grab a 180b clutch master and if your gearbox doesn't have a master then just search Ausrotary forums to buy one. Then it's a case of getting a length of metal brake line tubing with threaded ends on them. Down to about 30cm from the actual slave, then get a flexible brake line and attach it to the line and the slave then bleed.
I can get pics of my mounts and clutch setup if you like as I pulled out the rotar last week.
Cheers
Damo
Posted on: 2007/6/12 10:52
Drive It Like You Stole It
Every Car Has 500hp In The Wet
Team NEW SKOOL
Demojob can u up load pics would be great thanks
Posted on: 2007/6/12 11:55
From Warwick, QLD
sure I will take some tomorrow
Posted on: 2007/6/12 13:28
Team NEW SKOOL
From Melbourne AUS
some pics of mine...
(click to enlarge)
Posted on: 2007/6/12 13:53
1973 B110 A12
From Coondle, WA Australia
Looks great ange.
When my brother and I did a 12B Turbo into a 120y the biggest issue that we had was getting the drivelines to line up. It didnt matter where we put the motor, it hit something, so it was on a slight angle up and to the left.
It was freaking awsome, (wheel stands, instant smoke on demand,) but since the drive lines didlt line up, rego was a nogo, and it got the 1200 back in there and it was flogged off.
Just one question, slightly of topic.
What is the colour of your ute from?
Posted on: 2007/6/12 16:42
EARTH FIRST! - We can mine the other planets later...'
'69 Blue 4 door Project Daisy (http://www.datsun1000.com/TopicView.asp?TopicID=668)
(https://pcmhacking.net/forums/viewtopic.php?f=15&t=5640)
(http://mx5cartalk.com/forum/viewtopic.php...
From Melbourne AUS
im assuming you meant 12a turbo? or 13b?
anyway, yes its a mission to obtain a practical driveline angle with rotaries in a small datsun. i had months of teething problems with wearing uni's and driveline vibrations. now with a huge tunnel and recessed datsun crossmember have it at a workable angle and its working well.
lots of fun to drive.
the colour is holden hothouse green.
Posted on: 2007/6/13 13:03
1973 B110 A12
« 1 (2)
